Potential Energy of Oscillating surface
catmando
A rectangular sheet of thin material is rolled into a portion of a circular cylindrical surface of radius r. It rests under the action of gravity on a fixed cylindrical surface of radius R, symmetrical about the vertical centre line as shown below. If rolled slightly to the left or the right and released, the object will rock from side to side (assume no slipping).
write an expression for the gravitational potential energy of the object at some instant during the oscillation. Use the rest position of the centre of mass as the potential energy datum
ht tp://s11.postimage.org/gdrfgsoep/lol.jpg
b = k*r
PE = mgh
h = b - x
x = (R+r) - (R+r)cos(β)
b = kr - a
a = kr cos (β + θ)
h = kr +kr cos (β + θ) -(R+r) + (R+r)cos(β)
therefore potential energy
PE = mg(kr +kr cos (β + θ) -(R+r) + (R+r)cos(β))
hi catmando! :smile:
catmando said:
h = b - x
b = kr - a
a = kr cos (β + θ)
i don't follow your reasoning :redface:,
(perhaps you could mention O and OG?)
but your answer is certainly correct :smile:
(except for a minus sign :wink:)
to finish it, what is θ as a function of β ?​
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
