Can the TE01 mode be used in an air-filled rectangular waveguide at 10 GHz?
  • Thread starter Thread starter faraaa
    Waveguide Waves
faraaa
How to solve this problem?
An air-fi lled waveguide of rectangular cross-section (1 cm x 2 cm) is used to
carry EM waves at a frequency of 10 GHz.
Show that only the TE01 mode can be used?
I tried to find the cut-off frequency ( 7.5GHZ) and is that enough to prove that only TE01 can be used?
An air-filled waveguide of rectangular cross-section (1 cm x 2 cm) is used to
The answer to your question is no. You haven't justified your answer mathematically.
Use the formula for cutoff frequency fc(m,n,a,b) where m,n are the mode descriptors Tmn and a and b are the waveguide dimensions. Then show that the only possible mode is TE01. Remember to distinguish between a and b with respect to the cutoff formula.
PS the TM01 mode requires one extra step beyond just using the fc formula.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
