Master equation for Ornstein-Uhlenbeck process
  • Thread starter Thread starter cjolley
    Master Process
The discussion revolves around the formulation of the Ornstein-Uhlenbeck process and its master equation as defined in N.G. Van Kampen's "Stochastic Processes in Physics and Chemistry." The transition probability T_{t}(y_{2}|y_{1}) approaches a delta function as time t approaches zero, complicating the small-t expansion needed for defining the master equation. Participants highlight that the Ornstein-Uhlenbeck process can be related to the Fokker-Planck equation, which describes the time evolution of the probability distribution. A suggestion is made to consider the Langevin equation, which incorporates Gaussian noise, as a means to derive the necessary transition rates. The conversation emphasizes the need for a clear understanding of the small-t behavior of the process to establish a meaningful transition probability.
cjolley
Hi everybody...
I've been working through N.G. Van Kampen's "Stochastic Processes in Physics and Chemistry" and have run into something that has got me sort of stumped. He defines the Ornstein-Uhlenbeck process (a stationary, Gaussian, Markovian random process) in terms of the transition probability between two values y_{1} and y_{2} separated by a time t:
T_{t}(y_{2}|y_{1}) = (2π(1-e^{-2t})^{1/2}\exp(\frac{(y_{2}-y_{1}e^{-t})^{2}}{2(1-e^{-2t})})
and the probability distribution
P_{1}(y_{1}) = (2π)^{-1/2}e^{-y_{1}^{2}/2}
(This is pg. 83 if you have the book.)
A little bit later, he defines the master equation by expanding T_{t}(y_{2}|y_{1}) in powers of t and defining the coefficient of the linear term as W(y_{2}|y_{1}), the transition probability per unit time (pg. 96 if you have the book).
The thing that's got me stuck here is that, as t→0, T_{t}(y_{2}|y_{1})→δ(y_{2}-y_{1}), since T_{t}(y_{2}|y_{1}) is a Gaussian. I can't seem to come up with a reasonable way to expand this in terms of small t, which makes it difficult to define the master equation.
So... does anyone know how the Ornstein-Uhlenbeck process is formulated as a master equation? Any ideas would be greatly appreciated.
--craig
For small t, 1-e-2t ≈ 2t. This gives a Gaussian with variance ≈ 2t, which -> delta function as t -> 0.
Exactly. But that still doesn't tell me how to get a small-t expansion for y_{1} ≠ y_{2}, which is what I need for a meaningful transition rate.
The point is that y is a random variable. I don't know that book, but what he finally should get at, I guess, is that the Fokker-Planck equation for the time evolution of the distribution function is equivalent to a Langevin equation, which is an ordinary stochastic differential equation with Gaussian-distributed (white) noise.
For a simple derivation (however for the relativistic case) see
http://fias.uni-frankfurt.de/~hees/publ/hq-qgp4-bibtex.pdf
p. 41ff.
e-t≈1-t, so y1-y2e-t≈y1-y2-ty2. The net result for the integrand as t -> 0 is δ( y1-y2)
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
