Calculating Chain Forces on a Swing: Midterm Problem Help
  • Thread starter Thread starter ajc9387
    Midterm
To calculate the forces exerted by each chain on a swing, consider the system's equilibrium and the distribution of weights. The swing has a total weight of 250 N, with an 850 N person and a 40 N soda can positioned asymmetrically. The center of mass is crucial for determining torque, and the forces in the chains must balance the weights acting on the swing. The chain closer to the soda will support less weight, while the chain near the person will bear more, with the total tension in both chains equating to the combined weight of the swing and the additional loads. Understanding the distribution of weight based on position is key to solving the problem effectively.
ajc9387
Hey
My midterm is tomorrow and i don't know how to do this! See if one of you does.
A 850 N person sits 1.2 m from one end of a swing (5 m long) supported at each end by a chain. The swing weighs 250 N and there is a 40 N can of soda .5 m from the end opposite the person. How much force does each chain exert?
Any and all help is greatly appreciated!
Ajc9387
Wo- that's a toughy :-p. Here's what I'd do.
There are two things to help us understand the problem here.
First, the center of mass (CM) of the swing is located at its geometrical center, (i.e. 2.5m from each end) and it serves as its axis of rotation. Now, clearly the swing is not more rotating than it is accelerating linearly, so the sum of the torques about the CM must be 0. The person exerts a positive torque about the CM, and the can exerts a negative one. So the tension will have to exert a torque that cancel the sum of those torques. You can surely figure out which one of the two chains will apply that torque, and the value of the force (tension) producing it.
Second thing is the weight of the swing. This force, in so far as we consider that it is a force acting solely at the CM, exerts no torque about the CM. This is where I don't really know how to justify it, but I'd say the chains equally split the burden of supporting the bench, meaning you must add to each of the tensions found previously, 125 N.
So, basically, the chain near the soda has tension 125 N and the chain near the person has tension higher than that.
try this...
ajc9387 said:
Hey
Ajc9387
i'll assume the whole system is at rest, so i don't blow a brain cell on this one!
each chain will support "its part" of the masses hanging from it!
assuming the swing is of uniform density (if not, go out for pizza...), each chain supports what fraction of the swing alone? (half!)
if the soda can or the person were (or could) be supported by either chain alone (i.e., they could sit right at the end of the swing, or straddle the chain), that chain would support 100% of the weight and the other chain would be supporting none of their weight. if the can or the person sat in the middle, each chain would support half of the weight.
can you see what's coming? the one chain or the other chain has to support between zero and 100% of the weight of anything sitting on the swing, (plus the swing), and the fraction of the weight of the soda can OR the person is directly (and linearly) related to their position on the swing.
i'd prefer you use this logic to figure out how to solve the problem from here on, ok?
go for it!
