Tension and frequency relationship on a violin
The tension in a violin string is directly related to the frequency of the sound it produces, as described by the equation T = v^2 (μ), where μ represents mass per unit length. An increase in string tension results in a higher frequency, since the wave velocity (v) increases with frequency (f) and wavelength (λ). This relationship is fundamental to tuning the strings of a violin, as adjusting tension alters the pitch. Thus, increasing tension leads to a corresponding increase in frequency. Understanding this relationship is essential for proper string instrument tuning.
CAF123
There is an equation relating the tension in a string fixed between two nodes and the velocity of the traveling waves which form the allowed standing waves. It is T = v^2 (μ) where μ is the mass per unit length.
Am I correct in saying that if the tension in the string increases then frequency also increases? I say ths because v= fλ and if f increases then so does v and subsequently, by the above formula, T.
Thanks.
You are correct. This is how you tune the strings: by adjusting their tension.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
