Transformations of Discrete RVs
The discussion focuses on the transformation of discrete random variables, specifically how to derive the joint probability distribution function (pdf) for new variables U and V defined as U = X + Y and V = X - Y from a given joint pdf f(x,y). The original joint pdf is defined for discrete values of X and Y, and the user initially struggles with summarizing the transformed variables. They identify the possible values for U and V but seek guidance on how to use the probabilities from the original joint pdf to create the new joint pdf f(u,v). Ultimately, the user resolves their query independently.
dogma
Hello out there,
I have a question about the transformation of discrete random variables.
I have a joint pdf given by:
f(x,y)=\frac{(x-y)^2}{7} where x = 1, 2 and y = 1, 2, 3
I can easily create a table summarizing the joint pdf of RVs X and Y, f(x,y). I now have a transformation of U = X + Y and V = X - Y.
I'm not quite sure how to go about creating a table to summarize the joint pdf of U and V.
To my feeble mind, it appears that u = 2, 3, 4, 5 and v = -2, -1, 0, 1 (with some numbers for u and v repeated).
How would I go about using u and v and the probabilities from the f(x,y) table to create (transform) the joint pdf, f(u,v)?
I would greatly appreciate someone pointing me in the right direction (i.e. a good, swift kick in the rear). I apologize in advance if some of my terminology is incorrect.
Thanks a bunch,
dogma
Well...all's well...figured it out.
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
