Wind force, drag, something :v
  • Thread starter Thread starter 520
    Drag Force Wind
The discussion revolves around understanding wind force and drag equations related to a cardboard sheet affected by a fan. The user seeks clarification on the wind force equation, specifically the constants involved, such as area, wind pressure, and drag coefficient (Cd). They express a preference for detailed explanations rather than links that may cause confusion. A suggestion is made to determine Cd by measuring drag force at various wind speeds and plotting the results. This approach can help in accurately calculating the drag coefficient for their specific setup.
520
Heyy uh I have this problem I'm confused about; there is a body at rest (a sheet of cardboard set at an angle to electronic scales) and a fan blowing at the surface area. There is noticeable difference when I adjust the speed of the fan, the angle it sits at and the distance to the fan. Anyway I need help with the wind force equations, if I have the right equations.
These are the ones I have:
(Wind force) F= A* P* Cd [A: area of item, P: wind pressure, Cd: drag coefficient <- Huh??]
and
(Wind pressure) (1/2)*(density of air)*(wind speed)^2*(Shape factor)
Can somebody explain what the constants are and how to work them out, I would prefer if the responses are explanations not just links that are going to confuse me further
Any help will do :)
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
