What Happens When You Pitch a Baseball at 90% the Speed of Light?
  • Thread starter Thread starter vhbelvadi
    Baseball
When a baseball is pitched at 90% the speed of light, it would disintegrate upon colliding with air particles, releasing immense energy due to relativistic effects. The discussion highlights the necessity of vacuum conditions in particle accelerators to prevent destructive collisions with air. At such high speeds, the kinetic energy of the baseball approaches its rest mass energy, leading to a significant energy release upon impact. The energy output from this collision would be calculated using E=mc^2, indicating a massive explosion. Overall, the scenario illustrates the extreme consequences of relativistic speeds on matter.
vhbelvadi
I came across this from xkcd today. The question seems interesting, but I was wondering if this expplanation quite covers this or are there other possibilities? (Also, is something wrong with this explanation?)
Basically they're dealing with a baseball pitched at relativistic speeds.
http://what-if.xkcd.com/1/
haha, yeah, something like that would probably happen. The ball would definitely get destroyed. Particle accelerators must be vacuum for this reason - if there was air in there, then the particles would collide with them. So if there was a ball going at this speed, then all the particles in the ball would collide with the air particles, giving off ridiculous amounts of energy.
@BruceW - An open air particle accelerator--my thoughts exactly!
So, basically, it's 150g of particles colliding with air molecules, so wouldn't the collision (for now let's assume there's no batter for a good distance) cause the entire ball to disintegrate resulting in the generation of energy we can't quite handle?
Or will it be within comparatively safe limits?
at 0.9c, the kinetic energy is at a similar level to the rest mass energy. And from what you know about E=mc^2, this is going to be a huge amount of energy since we have a tenth of a kilogram of mass to play with.
Edit: So, specifically, the energy output of the explosion will be of the order of c^2 times by 1/10 kilogram
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
