Chemistry Can a BS in chemistry do whatever a BS in physics does?
  • Thread starter Thread starter thetaobums
    Chemistry Physics
The discussion highlights the challenging job market for recent graduates in chemistry and physics, with a particular focus on the limited opportunities available for physicists. It notes that while the skill sets of chemistry and physics graduates have some overlap, they also differ significantly, affecting job prospects and roles. Chemists may be more adept at tasks like interpreting NMRs or proposing retrosynthetic schemes, while physicists approach problems differently, even within specialized fields. The job market for BS-level chemists is described as "OK," with positions available as analytical technicians, though these roles tend to be low-paying and unexciting. Advanced degrees, management experience, or sales records are often required for higher-paying positions. The conversation also touches on the need for clarity regarding salary expectations, suggesting that graduates in these fields should earn more than those with degrees in liberal arts or business.
thetaobums
I'm solely talking about recent grads in these two fields. The job market for chemists is pretty dismal; I'd imagine it's more true for physicists, is it not? But it seems to me the skills learned under these two degrees are quite similar...I mean any physics BS can work as a labrat and any chemist BS can do calculations designing fuelcells.
Well, for instance, could a graduate in physics interpret NMRs, or propose retrosynthetic schemes for molecules?
I'm sure there is a lot of overlap in terms of general transferables, but there is also likely to be work that only chemistry or physics grads will have enough of a handle on to be reasonably successful in
the skillsets are quite different. chemists think differently from physicists, even physical chemists and condensed matter physicists think very differently about the same problem. they don't even think about silicon the same way, so why would they think of anything else the same way?
the JOB market is OK for BS level chemists. it wasn't hard to get an analytical tech position. its boring and the pay is low but its work. the high paying job market requires some sort of advanced degree, management experience, or sales records. For the grad level, I think specialization matters greatly.
By saying the pay is low what do you mean?
Could you give us a range of what to expect? I assume someone in your case should make more then someone with a lib. Arts. Or buss. Mjor.?
