Concentrated Photovoltaics, Parabolic Mirrors
The discussion centers on the potential efficiency of using parabolic mirrors to focus light onto small solar panels, as opposed to traditional solar panel fields. Participants highlight that concentrating sunlight can increase photovoltaic efficiency by raising current density and voltage, provided that the cells are adequately cooled to prevent damage and manage leakage currents. There are references to existing photovoltaic concentrator systems and the advancements in this technology over recent years. The conversation also touches on the benefits of using more expensive, efficient materials for smaller cell areas. Overall, the idea of concentrating photovoltaics is seen as a promising avenue for improving solar energy efficiency.
mnmman
The idea of a parabolic mirror to focus light onto a small solar panel popped into my mind the other day. I searched Google and this is about the best thing I found-
http://www.greenrhinoenergy.com/solar/technologies/pv_concentration.php
and
http://www.aps.com/main/green/Solana/Technology.html
Wouldn't focusing light toward one little panel be way more efficient than the fields of panels that I keep seeing more and more of? It seems to me that the Arizona plant is using the heat from this concentrated light to boil water and turn steam turbines. Good idea but why not instead use the light itself pointed at a photovoltaic cell? Can someone help me make sense of this?
and
Welcome to the PF.
You could maybe do a 2:1 concentration or so. What issues do you see with doing a higher concentration of sunlight on solar cells? Have you learned about reverse leakage current yet?
It was experimented the big scale at Madrid's Complutense university in 1994, with concentration factors >20.
Concentration is one sensible way to use photovoltaics, yes. Not only does it drop the cost of the collecting area, it also raises the cell's efficiency because the higher current density means a higher voltage... BUT this holds as long as you can cool the cells so (1) they don't burn (2) the leakage current stays reasonable.
Some designs put the cells against passive fin coolers in air. Others let a cooling liquid circulate.
An other avantage: as the cell area drops, you can afford more costly technology, like monocrystalline silicon, or GaAs, InP... which are more efficient.
Welcome to the PF.
I don't see any issues, other than what Enthalpy said, but I don't know much about electricity. I understand what leakage current is, but can't make sense of reverse leakage current.
mnmman, Welcome to Physics Forums!
Here is a description of two large large photovoltaic concentrator power systems:
Photovoltaic concentrator technology development:
Description/Abstract
This paper summarizes the progress that has been made in the past 18 months in the area of photovoltaic concentrator technology development. A brief description of the status of two new photovoltaic concentrator power systems, the 300 kW ENTECH-3M-Austin system, and the single-pedestal Alpha Solarco system is given.
http://www.osti.gov/energycitations/product.biblio.jsp?osti_id=6909974
Here is an excellent review of many types of concentrators:
http://www.google.com/url?sa=t&rct=...ps3ZnU6QBepTj1sEw&sig2=co1U4TiE6EGUpFxLSuz1Qw
thanks for all the replies, looks like I got a lot to learn.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
