Induced emf when dropping a magnet into a solenoid
The discussion revolves around understanding the induced electromotive force (emf) when a bar magnet is dropped into a solenoid. As the magnet approaches the solenoid, the magnetic field increases, leading to a change in flux linkage, which induces an emf. When the magnet is fully inside the solenoid, the flux linkage remains constant, resulting in no induced emf. Confusion arises regarding the net magnetic flux linkage and its impact on emf, with clarification that flux linkage is maintained even as the magnet moves through the solenoid. Ultimately, the key takeaway is that emf is induced only when there is a change in flux linkage, not when it remains constant.
sgstudent
I am having some trouble understanding why and how the emf changes when a bar magnet is dropped into a solenoid.
As the magnet moves down (have not entered the solenoid yet) it experences an increase in magnetic field. As it enters the magnet it experiences an increase in magnetic still until it has entered all the way. At which, now at the back there is a decrease in magnetic field while at the front there is an increase, however because in the front there are more field lines overall it is still a increase. Once, it reaches the middle there is no everall change in magnetic field. As it drops down further, i am clueless on what happens. I think that since there are now more coils at the back, so overall there is a decrease in magnetic field.
Here is a diagram of what i think: http://i.imgur.com/feMhv.png
Thanks for the help! :smile:
Easiest way to understand what's going on is in terms of flux linkage. This is a topological idea. Consider two closed loops, A and B. A represents an electric circuit, B represents magnetic field lines (which are closed loops). If A and B are linked, like adjacent links in a chain, we have flux linkage. If the loops are not linked, we don't. If the loops are unlinked and we link them, an emf is induced in the circuit loop while the linkage is changing. If we unlink them an emf is induced in the opposite direction while the linkage is changing.
On the thumbnail I use this idea to try and explain what's happening in the case of the magnet dropping through a coil.
Hi Mr Wood :smile: Thanks for the explanation and diagrams it help me a lot. However, i am still confused about this.
when the magnet reaches this position: http://postimage.org/image/he6l7v6qd/full/, shouldn't the emf induced become zero?
This is because the magnet field lines do not cause any net magnetic flux linkage. And only when the magnet reaches this position:http://postimage.org/image/he6l7v6qd/full/ then a new emf should be induced.
I'm a bit confused about your diagrams. Both your links take me to the same pair of diagrams! But in each diagram (the one with the magnet near the top of the solenoid and the one with the magnet near the bottom) there's lots of flux linkage. Are you visualising the turns of the coil and the lines of flux like the links of a chain? [Incidentally it's a good idea in this context to continue the magnetic field lines round inside the magnet, as I did in my diagrams, emphasising that the field lines are themselves closed loops.]
Don't know what you mean by 'not causing any net magnetic flux linkage'. There's plenty of flux linkage in each case. The flux is linked with different turns of the solenoid, but that doesn't matter at all, as all the turns are all in series.
As the magnet goes from the top position to the bottom, the flux linkage doesn't change, so that's why there's no emf while the magnet is inside the coil. Not that there's no flux linkage.
hi, sorry my first diagram is the first position i was mentioning while the box is the solenoid. So since there is no change in the flux linkage once it reaches postion 1 from the link to position 2, there will not be any emf produced? Thanks for the help!
Some physicists think about the magnet and solenoid situation in terms of cutting of lines of flux. This is absolutely fine, but I chose to discuss in terms of flux linkage, and changes in flux linkage. The two concepts are closely related, but shouldn't be muddled up together. Flux linkage is more versatile, because there are plenty of cases (such as inductors and transformers) where flux linkage changes without obvious cutting of flux, because there's no macroscopic movement of conductors.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
