Need help for IGBT parameter in PSIM
  • Thread starter Thread starter jagodzzinski
    Igbt Parameter
The discussion revolves around seeking assistance with IGBT parameters for a single-phase SPWM inverter using PSIM software. The user, jagodzziski, requests specific IGBT parameters and calculations for their 12V 50Hz inverter project. While some participants are unfamiliar with PSIM, they suggest alternatives like LTspice for obtaining IGBT models and emphasize the importance of understanding IGBT specifications such as voltage, current, and thermal requirements. Recommendations include consulting datasheets and possibly engaging with a power electronics expert for tailored guidance. Overall, the conversation highlights the need for precise IGBT parameter selection based on circuit design and operational conditions.
jagodzzinski
hello I am jagodzziski from poland i would like to ask u about PSIM software actually I am doing single phase SPWM inveter voutput 12V 50HZ .. may i know what parameter for igbt and may u show me the calcultion tq
Hi, jagodzziski. I guess none of us use PowerSim. So, I cannot help you with the software. I personally use OrCAD PSpice.
As for IGBT, are you asking for model parameter or a specific model?
If you have planned a specific model please mention it. I'll try to solve the circuit for you.
ooh really ..hmm I am not familiar with that software but mine share ur single phase inverter cct that produce spwm..btw thanks for ur rply mr Kholdstare ..sorry for my bad eng.
Hello jagodzziski,
Thank you for reaching out for help with PSIM software. I am not an expert in PSIM, but I can provide some general information about IGBT parameters and calculations.
IGBT stands for Insulated Gate Bipolar Transistor, and it is a type of semiconductor device commonly used in power electronics for switching and amplification. The important parameters for IGBTs include the maximum voltage, current, and power ratings, as well as the switching frequency and gate drive voltage.
For your single phase SPWM inverter with a 12V 50Hz output, the IGBT parameters will depend on the specific design and requirements of your circuit. Some factors to consider when selecting IGBT parameters include the load, input voltage, switching frequency, and desired efficiency.
To calculate the IGBT parameters, you will need to determine the maximum voltage and current that will be present in your circuit, taking into account any safety margins. You will also need to consider the power dissipation and thermal requirements for the IGBT to ensure it can handle the expected load and switching frequency.
I would recommend consulting with a power electronics expert or referring to the datasheets of specific IGBTs to find the appropriate parameters for your circuit. Additionally, PSIM may have a built-in tool or tutorial to help with IGBT parameter selection and calculation.
I hope this information helps you in your project. Best of luck with your inverter design.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
