Opposites Attract: Understanding O Notation in Math & CS
  • Thread starter Thread starter Max.Planck
    Cs Notation
The discussion clarifies the use of the O notation in mathematics and computer science, highlighting that the limit approaches differ: mathematics uses limits as x approaches 0, while computer science uses limits as x approaches infinity. Despite seeming contradictory, both interpretations are valid within their contexts. The key is to specify the limit when using O notation, as this determines the outcome. This distinction resolves the confusion regarding the application of O notation in different fields. Understanding these nuances is essential for accurate mathematical and computational analysis.
Max.Planck
Hi, I noticed in mathematics the O symbol is used in the following way:
A term T is in O(x^p), if lim x->0 T/x^p=c, for a constant c.
While in computer science the O symbol is used is this way:
A term T is in O(x^p), if lim x->∞ T/x^p is a constant.
What gives, these two notations seem to be the complete opposite of each other?
Mathematics news on Phys.org
The O symbol is valid in both cases. It is up to you to define what the x limit is.
But don't they contradict each other?
For example, in the first case x^7 is in O(x^5), but in the second case it is not.
No, they are just two distinct cases of a general concept. We should aways say "f(x)= O(g(x)) as x-> a and specify a. They are using two different values of a and so getting two different results.
Aha, thanks!
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
