Criteria for Solving this equation
  • Thread starter Thread starter smooney
    Criteria
The equation H^5 -10*L*H^4 +25*L^2*H^3 -25*Q^2/K^2 = 0 is a fifth-order polynomial in H, which cannot be solved using a general formula. Without specific numerical values for the constants L and K, the equation lacks a straightforward analytical solution. Numerical methods, such as iterative procedures in Excel, are recommended for finding solutions when constants are known. While special functions like Jacobi theta functions can theoretically provide solutions, they are complex and impractical for most applications. Therefore, numerical approaches are the most effective way to solve this equation.
smooney
Is it possible to solve this equation in terms of H without knowing any numbers? If so what method would I use? If I had numbers I think I could solve it numerically in excel. It's been a few years since I was in school and am fairly (very) rusty:
L,K = Constant
Any help would be appreciated, Thanks!
Mathematics news on Phys.org
You have a fifth order polynomial in H. There is no general formula which can solve this equation. If you have numerical values for your constants, then an iterative procedure (perhaps using Excel) would be the way to calculate solutions.
There is no simple formula giving Y as a function of L, H, Q, K because it is a polynomial equation of the fifth degree.
Such formula exists, but involving special functions : the Jacobi theta functions. But, in practice, it is much simpler to use numerical methods to solve the equation.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
