Forumlae for delay in pair-wise twisted single conductors for frequencies>10MHz
  • Thread starter Thread starter freddyfish
    Conductors Delay
Calculating the delay of impulses in twisted single conductors at frequencies above 10 MHz requires consideration of propagation velocity, loss versus frequency, and dispersion. Traditional formulas may not apply due to the high frequency of the signals, necessitating caution to avoid common pitfalls. The specific characteristics of the cables, including insulator type, shape, and size, significantly impact the results. Users are encouraged to provide details about the cables and distances involved for more tailored advice. Understanding these factors is crucial for accurately assessing pulse delays in high-frequency applications.
freddyfish
I would like to know if anyone knows any good formulas for calculating the delay of impulses in single conductors twisted around each other when the period of the impulses is 1μs and the pulses are 20ns long.
Some of the usual relations are no longer applicable in this case due to the very high frequency, so I am fishing for some tips and some warnings about all the pits you can fall into facing a problem like this.
Thanks
Thanks
The main things to look in the cable specs are are the propagation velocity, the loss versus frequency, and the dispersion. What specific cables are you looking at?
What distance!
And what insulator, shape, size...
Depending on that, you can receive a delayed pulse, or more often, a thing hard to recognize, because of dispersion.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
