A rather straight forward function question.
  • Thread starter Thread starter Dangshnizzle
    Function
A square centered at the origin has vertices on the axes, and the function f(x) = ax² - 4 must pass through three of these vertices. The solution reveals that 'a' equals 0.25, which is derived by evaluating f(0) = -4, confirming one vertex. The vertices of the square are identified as (4,0), (-4,0), (0,4), and (0,-4), simplifying the process to find 'a'. The discussion concludes with the confirmation that the correct function is f(x) = (0.25)x² - 4, establishing the relationship between the function and the square's geometry.
Dangshnizzle
The problem statement:
A square centered at the origin has its vertices on the x- & y- axes.
The graph of the function f(x)=ax2-4 , a>0
Passes through three of the square's vertices.
You must find what 'a' makes this statement true.
Other things to know:
Well I think there are multiple solutions to the problem. But I only need one. It would really help if you could show work and explain how you got your answer.
Thanks in advance to anyone who assists.
Solved:
f(x)=(0.25)X2-4
'a'=0.25
If you plug in x = 0, you get f(0) = -4. That gives you one of the vertices, right?
Yeah so you are saying that because it is a square, it has to have vertices at
(4,0),(-4,0),(0,4), and (0,-4)? Hahah genius. So now it's much simpler to find the formula for what 'a' must be.
Yes, that's right.
jbunniii said:
Yes, that's right.
Solved:
f(x)=(0.25)X2-4
'a'=0.25
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
