How much does lumped element model effect our analysis?
The discussion highlights the implications of using lumped element models to simplify continuous systems into discrete components like resistors and capacitors. It raises concerns about potential errors in calculations due to this abstraction, questioning the limits of such models. Specific factors that can lead to deviations from real behavior include temperature fluctuations, high current applications, and high-frequency effects. These factors can alter the performance of resistors and other circuit elements, potentially leading to inaccurate analyses. Understanding these limitations is crucial for improving the accuracy of circuit modeling and analysis.
Avichal
Previously I never noticed that we are making this abstraction - to abstract continuous systems into an idealized discrete element like resistor or capacitor.
So since we have made this approximation, what kind of errors can occur in our calculations? Does this approximation ever fail so that our calculations just deviate away from the real thing?
All models have some limits.
Resistors behave differently if you measure their voltage very precise (it will fluctuate due to its temperature), apply a high current (it will increase its temperature and change its resistance), apply an even higher current (it can melt), use a high frequency and so on. Similar effects can happen in other elements of circuits (including cables) as well.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
