Quantum Mechanics, a free particle prepared as a gaussian wavepacket
Cogswell
The problem is given in the attached image. I'm currently trying to work out question one.
\phi (k) = \dfrac{1}{2 \pi} \int_{- \infty}^{ \infty} \Psi (x,0) e^{-ikx} dx
Okay, so the first thing I did was to normalise it, but then I realized it was already normalised, so there's no need to do so there.
Using the above relevant equation:
\phi (k) = \dfrac{1}{2 \pi} \left( \dfrac{2a}{\pi} \right)^{\frac{1}{4}} \int_{- \infty}^{ \infty} e^{-ax^2} e^{ik'x} e^{-ikx} dx
\phi (k) = \dfrac{1}{2 \pi} \left( \dfrac{2a}{\pi} \right)^{\frac{1}{4}} \int_{- \infty}^{ \infty} e^{-ax^2 + ik'x -ikx} dx
\phi (k) = \dfrac{1}{2 \pi} \left( \dfrac{2a}{\pi} \right)^{\frac{1}{4}} \int_{- \infty}^{ \infty} e^{-[ax^2 + (ik - ik')x]} dx
Using the hint, ## ax^2 + (ik - ik')x = u^2 - \dfrac{(ik - ik')^2}{4a} ## where ## u = \sqrt{a} \left( x+\dfrac{(ik-ik')}{2a} \right)##
And therefore ## du = \sqrt{a} dx ##So then the equation becomes:
\phi (k) = \dfrac{1}{2 \pi} \left( \dfrac{2a}{\pi} \right)^{\frac{1}{4}} \int_{x = - \infty}^{ x = \infty} exp - \left( u^2 - \dfrac{(ik - ik')^2}{4a} \right) dx
\phi (k) = \dfrac{1}{2 \pi} \left( \dfrac{2a}{\pi} \right)^{\frac{1}{4}} \int_{x = - \infty}^{ x = \infty} e^{-u^2} e^{\dfrac{(ik - ik')^2}{4a}} \dfrac{du}{\sqrt{a}}\phi (k) = \dfrac{1}{2 \pi} \left( \dfrac{2a}{\pi} \right)^{\frac{1}{4}} \dfrac{1}{\sqrt{a}} e^{\dfrac{(ik - ik')^2}{4a}} \int_{x = - \infty}^{ x = \infty} e^{-u^2} du
Now how do I change the bounds of integration? If there were still from negative infinity to positive infinity, I'd get ## \sqrt{ \pi} ## for the integral part, so is that right?
I feel like it's not from negative infinity to infinity though.
The bounds look correct, as your definition of u goes toward -∞ as x goes to -∞, and ∞ as x goes to ∞ (provided that \sqrt{a} is taken to be positive, if it's not, the integral just becomes negative and the \sqrt{a} in front of the integral will make it positive again).
Okay thanks.
I have done question 2 and this is what I got:
\Psi (x,t) = \dfrac{\dfrac{1}{2 \sqrt{2a}} \left( \dfrac{2a}{\pi} \right) ^{\frac{1}{4}} exp \left( \dfrac{(ix - \frac{2k'}{4a})^2}{4[\frac{1}{4a} + \frac{iht}{2m}]} \right)}{\sqrt{\frac{1}{4a} + \frac{iht}{2m}}}
where exp is the exponential function.
I asked a friend and he said he also got something this messy for the answer.
However, I run into trouble when I try to do the expectation values of ## x ## and ## x^2 ## for question 3.
I remember my lecturer saying something about a way of solving this (if you know ##<x>## and ## \sigma_x ## then you can work out ## <x^2> ## without having to evaluate 2 more gaussian integrals.
So to work out ##<x>## I use:
&lt;x&gt; = \int^{\infty}_{- \infty} \Psi (x,t)^* (x) \Psi (x,t)dx
And of course I can extract out the constants so I get:
&lt;x&gt; = \left( \dfrac{\dfrac{1}{2 \sqrt{2a}} \left( \dfrac{2a}{\pi} \right) ^{\frac{1}{4}} }{\sqrt{\frac{1}{4a} + \frac{iht}{2m}}} \right)^2 \int^{\infty}_{- \infty} x \cdot exp \left( \dfrac{(ix - \frac{2k&#039;}{4a})^2}{4[\frac{1}{4a} + \frac{iht}{2m}]} \right) exp \left( \dfrac{(-ix - \frac{2k&#039;}{4a})^2}{4[\frac{1}{4a} - \frac{iht}{2m}]} \right)
&lt;x&gt; = \left( \dfrac{\dfrac{1}{2 \sqrt{2a}} \left( \dfrac{2a}{\pi} \right) ^{\frac{1}{4}} }{\sqrt{\frac{1}{4a} + \frac{iht}{2m}}} \right)^2 \int^{\infty}_{- \infty} x \cdot exp \left( \dfrac{(ix - \frac{2k&#039;}{4a})^2}{4[\frac{1}{4a} + \frac{iht}{2m}]} + \dfrac{(-ix - \frac{2k&#039;}{4a})^2}{4[\frac{1}{4a} - \frac{iht}{2m}]} \right)
I don't really know what to do now because I have imaginary's on the top and bottom of the fraction. It doesn't really seem like a gaussian integral.
Anyone know what I can do or if there's an easier/better way to do this (my lecturer said I can do all of question 3 on one page if I knew the shortcuts)? Doing the ## <x^2>## will be similar to this as well I presume.
huh, how would I got about opening the attachment?
I don't know, I'm sure I attached it before.
Here it is again... hopefully it works
I think your lecturer was talking about finding &lt;x^2&gt; with the relation σ=\sqrt{&lt;x^2&gt; - &lt;x&gt;^2}
Yea I've already solved it... I just have to transform this:
into the form \dfrac{1}{ \sigma \sqrt{2 \pi}} \int_{- \infty}^{\infty} e^{\frac{-(x- \mu)^2}{2 \sigma ^2}}
using a few algebra tricks and compare co-efficients. This is just the general equation for a normal distribution.
The function is already normalised and so ## \mu ## is the expectation value of x and ## \sigma_x ^2 ## is the variance and I can use those 2 things to work out ## <x^2> ##
