Spin 1/2 particle in |z+> state hits a magnetic field
StarTiger
"A spin 1/2 electron in a hydrogen atom is placed in a time-independent magnetic field B=B0(k)
The electron's spin starts in the |z+> state at t=0.
Calculate probability o ffinding the electron in the |y-> state as a function of time for t>0.
Basically I'm just confused about what to do about there being a z and y direction. I know how to calculate probabilities for spin states.
If you know all these things, you can do it.
1. Can you write down the Hamiltonian for the system?
2. Using the Hamiltonian, can you write the time-dependent state of the particle?
3. Back to basics. What is the projection of the time-dependent state onto |-y>?
4. If you know the projection, what's the probability?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
