Why degrees are equal if polynomial are equal?
If two polynomials f(x) and g(x) are equal, they must have the same degree, as their graphs would coincide only if their degrees match. The discussion explores the proof that if f(x) = g(x) for all x, then the difference f-g is the zero polynomial, which has infinitely many roots. This implies that f and g cannot differ in degree, as non-zero polynomials have only a finite number of roots. Additionally, the conversation touches on exceptions in finite fields, where polynomials can have the same graph but different degrees. Overall, the consensus is that equality of polynomials necessitates equality of their degrees.
Avichal
Two polynomial f(x) and g(x) are equal then their degrees are equal.
This is a very trivial statement and it shouldn't worry me much but it is.
I get an intuitive idea why they should be equal. Their graphs wouldn't coincide for unequal degrees.
But what if somehow the coefficients make f(x) = g(x) for all values of x?
Is there a more rigorous proof for this statement?
Mathematics news on Phys.org
? if f(x)=g(x) then of course they are of the same degree, the two functions are equal.
I'm not quite sure what you're asking, if two functions are the same then everything about them are equal.
First assume our field is infinite, like R or C. The difference between two polynomials is a polynomial, so f−g is a polynomial. Since f(x)=g(x) for all x, this means that f−g have infinitely many zeros, whence f−g=0.
Now, for Z/pZ , p prime, we have x^p−a=x−a, since x^p=x
Yes, I know its obvious. But I was looking for a proof.
Thanks for the proof.
By your last line are you suggesting that this isn't always the case.
If you are using the two-element field (i.e. GF[2]) then the polynomial function f(x) = x3 + 1 and the polynomial function g(x) = x + 1 both have the same graph:
0: 1
1: 0
As formal polynomials they have different degrees. But as polynomial functions they have the same graph.
Assuming fields of characteristic zero , re the cases brought up above by jbriggs and rattan, maybe you can use the Fundamental Theorem of Algebra (considering complex roots ), to argue that both must have the same roots and therefore the samenumber of roots.
Otherwise,how about this: if f=g, then f-g =0 is the zero polynomial ( not just the number zero). But every
non-zero polynomial has only finitely-many roots, while the zero polynomial (over char. zero ) does not. Then
f-g must be the 0 polynomial:
0*x^n +0*x^{n-1)+...+0*x+0.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
