musicgirl
- 12
Hi,
I want to use a module to repeatedly calculate a parameter in NDSolve, but I seem to be having trouble. Here is a simplified version of what I'm doing. In this example, I want to use the difference between v1 and v2 at a given timepoint to calculate the connection between v1 and v2 for the next timepoint.
I am getting the error "NDSolve::ndnum: Encountered non-numerical value for a derivative at s == 0.`." but as far as I can see, everything is defined in the module. If I replace Tau with a constant, I get no errors, which leads me to think it must be something to do with the way I am sampling the value of v1 and v2 from the main NDSolve loop?
Thanks for your help
connection[vdiff_, t_] :=
Module[{deltav = vdiff, Tau, con},
Tau = 120 + 7434.49/(1 + 0.00262985 (deltav[[1]])^2);
con = NDSolve[{g' == (1/Tau)*(3 - g), g[0] == 1},
g, {s, 0, T}];
g[t] /. con]
A = 3;
\[Epsilon] = 0.2;
\[Alpha] = 3;
\[Gamma] = 0.05;
v0 = 0.4;
w0 = 0.4;
T = 25;
initial =
Solve[wi == A*vi*(vi - \[Alpha])*(1 - vi) - w0 &&
wi == (vi - v0)/\[Gamma], {vi, wi}, Reals];
fitz = NDSolve[{v1'[
t] == ((A*v1[t]*(v1[t] - \[Alpha])*(1 - v1[t]) - w1[t] -
w0)/\[Epsilon])
+ (connection[v1[t] - v2[t], t]*(v2[t] - v1[t])),
v2'[t] == ((A*v2[t]*(v2[t] - \[Alpha])*(1 - v2[t]) - w2[t] -
w0)/\[Epsilon])
+ (connection[v2[t] - v1[t], t]*(v1[t] - v2[t])),
w1'[t] == v1[t] - \[Gamma]*w1[t] - v0,
w2'[t] == v2[t] - \[Gamma]*w2[t] - v0,
v1[0] == kick + vi /. initial,
v2[0] == vi /. initial,
w1[0] == wi /. initial,
w2[0] == wi /. initial},
{v1, v2, w1, w2}, {t, 0, T}];
con = NDSolve[{g'
g, {s, 0, T}];
g[t] /. con]
A = 3;
\[Epsilon] = 0.2;
\[Alpha] = 3;
\[Gamma] = 0.05;
v0 = 0.4;
w0 = 0.4;
T = 25;
initial =
w0)/\[Epsilon])
w0)/\[Epsilon])
