Challenge IX: Dealing with Mod 1 solved by mfb
  • Thread starter Thread starter micromass
    Challenge
The challenge proposed by Boorglar involves proving that a sequence defined by multiplying a positive real number a by natural numbers n will exceed 1/n infinitely often if it does not eventually become zero. The discussion outlines various cases based on the value of the sequence elements, leading to the conclusion that if the sequence avoids case 1 (where it becomes zero), it will cycle through cases 2 and 3 infinitely. A follow-up question explores conditions under which the sequence remains below 1/n infinitely, revealing that not all values of a and n allow this. The conversation also touches on the implications of the sequence's behavior in relation to its base n representation, emphasizing the significance of non-terminating decimal expansions. Overall, the problem was effectively solved, with contributions highlighting interesting mathematical properties and potential generalizations.
micromass
Staff Emeritus
Insights Author
This challenge was proposed by Boorglar. Many thanks to him!
Let n be a natural number larger than 1, and a be a positive real number.
Prove that if the sequence \{a\}, \{an\}, \{an^2\},... does not eventually become 0, then it will exceed 1/n infinitely many times.
Here {x} means x - floor(x).
Mathematics news on Phys.org
As x-{x} is an integer, {an}={{a}n} for natural numbers n.
This implies that it is sufficient to consider 0<=a<1. In addition, every value in the sequence depends on the previous value (and n) only.
As a special case, {0n}=0, for a=0 there is nothing to show.
Let ai={ani}.
  1. case ai=1/n or ai=0: Our sequence will end at 0, nothing to show.
  2. case 0<ai<1/n: There is a smallest k such that 1/n<aink<=1. If aink=1, our sequence becomes 0 and there is nothing to show. Otherwise, {aink} exceeds 1/n.
  3. case 1/n < ai < 1: Good, we found another element that exceeds 1/n. {an} will be one of the three cases again.
Each a which does not end up in case 1 has to stay in case 2 and 3, and case 2 always leads to case 3 in a finite number of steps. Therefore, case 3 gets visited infinitely many times.
Follow-up question: can we find general conditions such that the sequence is below 1/n infinitely many times?
This is not true for all (a,n), as the example a=1/2, n=3 shows.
^ This looks right to me.
A rephrasing toward some generalization.
Let G:=\{z\in\mathbb C:\enspace |z|=1\}=\{e^{i\theta}\}_{\theta\in\mathbb R}, a nice (compact abelian) topological group under multiplication. Fixing n, let f:G\to G be the n^{\text{th}} power map, a group covering.
Let A:= \left\{e^{i\theta}:\enspace 0&lt;\theta&lt; \frac1n\right\}\subseteq G. Note that f|_A is injective.
Let B:=\{z\in G: \enspace \nexists k\in \mathbb N \text{ with } f^k(z)=1\}, the set of elements that don't have finite order divisible by n.
We want to show that iterating f on any element of B crosses through G\backslash A infinitely many times. By the inductive argument mfb used (which works because f^{-1}(B)=B and f is surjective), it's enough to show that iterating f on any element of B crosses through G\backslash A at least once.
So an equivalent formulation is the following:
Show that there does not exist a nonempty S \subseteq A such that f(S)\subseteq S.
[Note that such S would be a subset of B as well, as it excludes 1.]
I think an interesting question is: What are some sufficient conditions on G and f:G\to G to ensure that for every connected A\subseteq G\backslash\{1\} on which f is injective, there does not exist a nonempty S \subseteq A such that f(S)\subseteq S?
Regarding the follow-up question, here are some calculations:
Let k be the greatest natural number such that ##A_k = \{a × 3^k\} < \frac{1}{3}##.
Let ##x = A_k##.
##0 < x < \frac{1}{3}##
##\{3x\} ≥ \frac{1}{3}##
##\frac{1}{9} ≤ x < \frac{1}{3}##
##1 ≤ 9x < 3##
##\{9x\} ≥ 1/3##
##\frac{4}{3} ≤ 9x < \frac{6}{3}##, ##\frac{7}{3} ≤ 9x < \frac{9}{3}##
##\frac{4}{27} ≤ x < \frac{6}{27}##, ##\frac{7}{27} ≤ x < \frac{9}{27}##
And so on, giving:
##A_k \in \{ x \in (0, \frac{1}{3}) : \forall k ≥ 0, \forall n ≥ 2, x \in \bigcup \; [ \; (1 + 3k)/3^n, (3 + 3k)/3^n \; ) \; \}##
This is an interesting set. I don't know that much about it but the smallest number it contains is ##\frac{1}{6}##, the limit of this sequence: ##\frac{1}{9}, \frac{4}{27}, \frac{13}{81}, \frac{40}{243}, \frac{3^n - 1}{6.3^n}##. But this means ##\{y : \frac{1}{3} < y < \frac{1}{2} \land \{y × 3^n\} ≥ 1/3 \} = ∅##, for if there was such a y, ##\frac{y}{3}## would be a candidate for ##A_k## above, but ##\frac{y}{3} < \frac{1}{6}##.
So there is an interesting void between ##\frac{1}{3}## and ##\frac{1}{2}## where no number is such that the fractional part is never below 1/3.
Congratulations to mfb for giving a nice solution to the problem.
I'm wondering if there are nice solutions to the follow-up questions by mfb and economicsnerd. Verty already came up with something nice though.
Thanks everybody for their contributions!
Since the original question seems to have been solved, I might just as well post my own solution, which is basically the same as mfb's but more visual I guess.
Write a as a infinite decimal in base n. Then a = a_0.a_1a_2a_3... where 0 ≤ a_i ≤ n - 1. Multiplying by n is equivalent to shifting the decimal point towards the right, and taking the fractional part changes to 0 all digits left of the decimal point. So basically
\{an^k\} = 0.a_{k+1}a_{k+2}a_{k+3}....
If a is a rational number with denominator which divides n, then (as in base 10 for 1/2 and 1/5) the base n expansion eventually terminates and all remaining digits will be 0 which corresponds to the sequence becoming 0. Otherwise, if the base n expansion doesn't terminate then there will always be some non-zero digit no matter how far. When shifting, these non-zero digits will eventually arrive at the a_1 position and we have a number larger than 0.100000... which is 1/n. Since there are infinitely many nonzero digits, the sequence exceeds 1/n infinitely many times as stated.
For the follow-up, for the sequence to be below 1/n infinitely many times is equivalent to the number a containing infinitely many 0's in its base n expansion. So for example, if n = 3, then the numbers for which the sequence does not get below 1/n infinitely many times are those that end with an infinite sequence of 1's and/or 2's, such as:
0.10120(12)... or 0.2012112111211112111112... This set looks a bit similar to the Cantor set.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
19K
11K
15K
10K
11K
