Acceleration in Two Dimensions (Vector)
The discussion revolves around a physics homework problem involving a bird's flight path, requiring calculations of total distance traveled, total displacement, average speed, and average velocity. The bird's journey includes two segments with specified displacements and a total flight time of 18 hours. Participants emphasize the importance of understanding the definitions of total distance and total displacement to solve the problem effectively. They encourage reviewing class notes or textbooks for clarity on kinematic concepts. Engaging in the problem-solving process is essential, and assistance is offered once an attempt is made.
trapones
A bird flies from Lesser Slave Lake in northern Alberta to Dore Lake in northern Saskatchewan. The birds displacement is 800.0 km [E 7.5deg S]. The bird then flies from Dore Lake to Big Quill Lake, Saskatchewan. This displacement is 400.0 km [E 51deg S]. The total time of the flight is 18.0 hours. Determine the bird's
  1. total distance traveled
  2. total displacement
  3. average speed
  4. average velocity
Very many kinematic equations
∇Velx = Vfx - Vix
∇Vely = Vfy - Viy
ΔVel = √Vx^2 + Vy^2
Etc.
In order to provide you with help we need to see your attempt at solving the problem. Do you understand what each of the things you're asked to find is? For example, can you explain what the total distance traveled is? Can you explain what the total displacement is? I recommend you review you notes from class or refer to your textbook (or other online resources) if not. Once you understand these concepts and the difference between them the problem should be much easier.
If you're having difficulty ask for help, but we need to see some kind of attempt first. :)
