Three astronauts equipped with jetpacks
  • Thread starter Thread starter p14r
Three astronauts are using jetpacks to push a 121 kg satellite in space, applying various forces at different angles. The net forces in the x and y directions were calculated, resulting in Fnet x of approximately 101.84 N and Fnet y of about -18.33 N. The total net force was determined to be -103.47 N, leading to an acceleration calculation using Fnet = ma. The final acceleration was found to be -0.85 m/s², but clarification was needed regarding the use of the negative sign for magnitude. It was confirmed that magnitudes should be unsigned, resolving the confusion.
p14r
Three astronauts equipped with jetpacks are pushing a satellite, having a mass of 121kg, through space. The forces being exerted on the satellite are F1=31.8N at an angle of 31.0 degrees above the horizontal (θ1), F2=40.0N at 60.2 degrees below the horizontal (θ2), and F3=54.7N along the horizontal.
What is the magnitude of the satellite's acceleration?
So I tried to solve it by adding all the FnetX, and Fnet Y
Fnet x= 31.8 cos 31 + 54.7 + 40.0 cos 60.2
= 27.2579 + 54.7 + 19.8789584
= 101.8368786 N
Fnet y= 31.8 sin 31 - 40.0 sin 60.2
= 16.37821 - 34.71061813
= -18.332408 N
tan θ = 101.8368786 / -18.332408
θ = -79.79506177
sin θ = Fnet x/ Fnet
sin (-79.79506177) = 101.8368786/ Fnet
Fnet = -103.47 N
Fnet = ma
a = Fnet/m
a = -103.4737987 N/121 kg
a = -0.85 m/s^2
But apparently it's wrong, can someone help please?
p14r said:
Fnet = ma
a = Fnet/m
a = -0.85 m/s^2
Did you include the minus sign in your answer? They wanted the magnitude of the acceleration.
Yup i did, so i shouldn't enter the negative sign?
No you shouldn't. Magnitudes are unsigned.
It worked, thank you so much!
