Questions about inverting DC to AC
  • Thread starter Thread starter kettaneh
    Ac Dc
To calculate the working time of a 12V 7.2Ah lead-acid battery powering a 100W lamp through a 12V to 220V inverter, consider the battery's capacity of 86.4Wh, which can provide approximately 30-50 minutes of runtime, depending on inverter efficiency. The inverter's wattage should be calculated using the output side, meaning for a 100W load, a minimum 1000W inverter is recommended to account for losses. Discharging the battery quickly can significantly reduce its effective Ah rating, especially under high loads like 100W, which draws over 8.3A. Additionally, factors such as battery age, treatment, and ambient temperature can further impact performance. Understanding these elements is crucial for effective battery and inverter usage.
kettaneh
Hello,
I have a question, How can I calculate the working time for the following scenario:
I have 12V 7.2AH LEAD ACID SLA DEEP CYCLE BATTERY
Then I used DC 12V to AC 220V Power Inverter USB 1000W to give me AC
I connected one 100w lamp .. For how long it will work ? how can I calculate it
another question .. How can I calculate the watt of the inverter (to know which one I should buy) .. is it 220v x amp ? or 12v x amp ?
thanks
You will need the efficiency of your converter to find the power needed as input.
Assuming your battery is designed to deliver ~100-150W (check this!), it can store 12V*7.2AH = 86,4Wh, so it will run for something like 30-50 minutes.
The power rating of the transformer is probably for the output, so you should use the 220V-side. If the losses in the converter are small, the other side should give a similar result (the current will be much larger there, to account for the lower voltage).
For power inverters, the rating is always for the load. If you have 1000W of light bulbs (a resistive load), you need at least a 1000W inverter (can be larger but not smaller).
Something else to consider besides the efficiency of the inverter is your battery. The faster you discharge a battery, the lower the Ah rating becomes. Usually the Ah rating is taken for a 20 hour discharge period. If you discharge over a longer time it actually goes up slightly, but if you were to discharge your battery in say 5 hours, the Ampere-hours you realize can decrease considerably (plus you can damage the battery if the drain is too high).
In your example of a 7.2 Ah battery, the 20 hour rating would result in a 360 milliampere drain (for 20 hours), but with a 100W load, the current drain would be over 8.3 Amperes so the 7.2 Ah battery rating would be diminished substantially. Lower ambient temperatures will also decrease the Ah rating.
Lastly, the Ah rating of a given battery usually falls with the age of the battery and how it has been treated during that lifetime (rate of discharge, depth of discharge, number of discharge cycles, etc.)
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
