What are these mysterious structures on wireless chipsets?
The discussion focuses on the identification of mysterious structures found on wireless chipsets after careful decapsulation. Observers note that the substrate material appears to be glass (SiO2) and that the structures are not typical top layers of standard silicon integrated circuits, but rather standalone planar elements connected to a ground plane. Key features identified include an interdigital capacitor and a spiral inductor, suggesting these structures function as circuit elements. The unique planar design indicates they are not capacitively coupled to other components, differing from traditional silicon RF ICs. The conversation highlights the complexity and precision required in their manufacturing.
Andy Resnick
Education Advisor
Insights Author
Careful decapsulation of wireless chipsets results in these structures:
http://imageshack.us/a/img690/7145/9yd4.jpg
http://imageshack.us/a/img854/7783/kq3i.jpg
http://imageshack.us/a/img850/3041/xxki.jpg
http://imageshack.us/a/img826/2589/easq.jpg
I'm hoping someone can provide clues/insight as to what these are. The substrate material is likely glass (SiO2), about as thick as a MEMS cantilever, and are generally not top layers of a 'standard' Silicon IC- they are stand-alone planar structures connected to a ground plane (not shown).
Thanks in advance...
Difficult to tell.
The structure on the 3rd picture is a (or perhaps more than one ) interdigital capacitor. At the bottom of the 4th image I can also see a spiral inductor.
Right- I can recognize certain circuit elements from similar features on silicon RF ICs. On those silicon ICs tho, the coils etc. are just the top layer. These aren't capacitatively (is that a word?) coupled to anything- it's truly a planar circuit.
Never mind the manufacturing magic needed to fabricate a zillion of these every second...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
