What is the Threshold Energy of a Proton Beam to Produce 100 GeV Pions?
Kyrios
I am trying to find the minimum energy for a proton beam to make pions that have 100Gev of momentum. The proton beam is hitting a fixed target.
p + n -> n + n + ##π^{+}##
In the centre of mass frame, there is zero initial momentum. But the pion has 100GeV of momentum on the other side, so I gave the neutrons the same amount in the opposite direction to cancel it out.
Then I used E=2m##c^2## for the initial energy and got the relativistic mass. (I wasn't sure about this)
The velocity was very close to the speed of light, and I then used relativistic velocity addition to find gamma. (this is for the proton colliding with the neutron)
I had gamma ~ 9000
In the end I had an answer of ##E_{proton beam}## ~ 8.5 TeV
Is this the right sort of value to be looking at? If necessary I can write up all my working.
Isn't the 100 GeV momentum of the pion measured in the lab frame? If so, that's not the momentum of the pion in the center-of-mass frame.
How can I find out what the momentum is in the CoM frame? Do I still need the CoM frame?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
