Law of Conservation of Momentum and Jumping Off a Boat with Constant Velocity
  • Thread starter Thread starter pierce15
    Momentum
When a person jumps off a boat moving at constant velocity, the initial momentum should be calculated as the total mass times the boat's velocity, not as separate components. The correct equation for conservation of momentum is m1v1f + m2v2f = 0, where the initial momentum is considered relative to a stationary observer. This approach simplifies the problem by allowing the initial velocity of both the person and the boat to be treated as zero. After the jump, the final velocities can be adjusted to account for the observer's speed. Understanding these principles clarifies the application of momentum conservation in this scenario.
pierce15
If a person jumps off of a boat with constant velocity, should the equation resulting from the law of conservation of momentum be (where 1 denotes the mass/velocity of the person, 2 denotes those of the boat, and f denotes a final velocity):
m1 * 0 + m2 * v2 = m2 * v2f + m1 * v1f
or
m1* 0 + m2 * v2 = (m2-m1) * v2f + m1* v1f
or
Neither. The left hand side is wrong because the initial momentum is ##(m_1+m_2)v_2## and that's what has to be equal to the final momentum ##m_1v_{1f}+m_2v_{2f}##.
These problems are easiest to work if you start with the total momentum equal to zero, which in this case means that the initial velocity of the boat and person is zero. You can make the problem turn out that way just by using the speeds measured by a second boat that is pacing the first boat (relative speed zero) until the person jumps. Working with that definition, it's easy: ##m_{1}v_{1f} + m_{2}v_{2f} = 0##. Then you just have to remember to add the speed of the observer back in if you want to get the speed of the boat and/or the person relative to the shore.
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
