Building theoretical model for phase seperation
The discussion centers on the formation of a solid phase ABC from elements A, B, and C under rapid heating and cooling, with the addition of a fourth element, D, leading to a two-phase solid (AB, CD). The phenomenon is thermodynamically favorable, suggesting a solubility limit in the solid phase that affects the chemical potential of the phases. The challenges include the extreme conditions required for the experiment, which are difficult to replicate in the lab, and the lack of existing phase diagrams and prior research on the A-B-C-D system. Suggestions for computational methods and resources to explore include shock tubes for simulating high temperatures and pressures, as well as specific models like the BGK model of the Boltzmann Equation. The importance of using standard units, such as Pascals for pressure, is also emphasized for consistency in research.
susdu
I have three elements, A, B, C, that under certain conditions (rapid heating and cooling)
form one ABC phase solid. Sometimes when I add a fourth element, D, I get two phase (AB,CD) solid.
Obviously this phenomena is thermodynamically favourable. My guess (still undergraduate)
is that there is a solubility limit in the solid phase of these elements in a way that beyond a
certain amount of D, the chemical potential of the ABCD phase is higher than that of two-phase
solid.
I want to offer a model that will explain this phenomena. Problems are:
1. This is a process that occurs in high temperatures and pressure (4000K and 40,000psi in 1 millisecond) so it can't be easily reproduced in the lab.
2. I didn't find any phase diagrams of A-B-C-D and their combinations.
3. Prior research on the subject is almost non existent.
I really don't know where to start. This is not homework, it's a research project I'm interested in.
I'll appreciate any help/direction.
The conditions of your experiment are indeed difficult to reproduce in any laboratory! Some shock tubes for blast wave simulation have been operated at such temperatures and pressures, but are rare and expensive. An overview can be found here:
http://en.wikipedia.org/wiki/Shock_tube
Here a powerful and high pressure system is described:
http://arxiv.org/ftp/arxiv/papers/1105/1105.4670.pdf
Here is one computational method that possibly could be applicable:
“The Bhatnagar–Gross–Krook (BGK) model of the Boltzmann Equation”
http://www.math.ust.hk/~makxu/PAPER/aiaa-shock.pdf
One more computational method:
High temperature shock wave interaction in heavy gases - Computations
Bei Wang, Maryland, Univ., College Park; Harland Glaz, Maryland, Univ., College Park
http://arc.aiaa.org/doi/abs/10.2514/6.1999-3577
May I suggest you use the units “Pascals” for pressure, and not psi? These units are used throughout the literature.
40 000 pound/square inch = 275 790 291.2 pascal, or 275.8 Mpa
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
