Why must the upper limit match when integrating?
MathewsMD
For example, if you have the function f(x) = x2 then find:
d/dx any number3x∫ t2dt
Why must the dx in d/dx ∫f(t)dt always match the upper limit in order to compute the integral? Why is the lower limit of no concern? I know that you must take chain rule into consideration and change 3x to u, and then do du/dx but why does the upper limit only matter?
Any help would be great!
Huh I don't understand your question?
When applying the fundamental theorem of calculus, think about everything in terms of differentiation.
Say f:\mathbb R\to\mathbb R is some continuous, bounded function. For any a,b\in \mathbb R, let F(a,b)=\int_a^bf(x)\text{d}x.
The FTC tells us that differentiating F(a,b) by b gives f(b) (no matter what a is), and differentiating F(a,b) by a gives -f(a) (no matter what b is).
As an example, think about the case where f(x)>0 is your speed at time x, in which case F(a,b) (for a<b) is just how far you've traveled between time a and time b.
Talking about how fast you're going at time b doesn't require any information about when you started moving (i.e. time a).
You are making some assumptions that are unjustified- in particular that it is the upper
limit that is important!
In order to be able to differentiate with respect to x, you must have a function of x. One way to do that is to have one or the other limit of integration a function of x.
Both \int_0^x t^2 dt= (1/3)x^3 and \int_x^1 e^t dt= e- e^x are differentiable with respect to x.
Yet another is to have constant limits of integration while the integrand is a function of both x and the "variable of integration:
\int_0^1 e^{x+ t}dt= e^x\int_0^1 e^t dt= e^x[e- 1] is differentiable with respect to x.
(Strictly speaking, of course, a the integral does NOT have to have an "x" anywhere in order to be differentiable with respect to x! Of course, then, the derivative is 0.)
To elaborate on what Halls said what is important is the places where the variable appears. The general rule is called Leibniz integral rule and states that
$$\dfrac{d}{dt} \int_{\mathrm{a}(t)}^{\mathrm{b}(t)} \mathrm{f}(x,t) \, \mathrm{d}x = \int_{\mathrm{a}(t)}^{\mathrm{b}(t)} \mathrm{f} ^{(0,1)}(x,t) \, \mathrm{d}x + \mathrm{f}(\mathrm{b}(t),t)\mathrm{b}^\prime (t)-\mathrm{f}(\mathrm{a}(t),t)\mathrm{a}^\prime (t) \\ \text{where } \mathrm{f} ^{(0,1)}(x,t) \text{ is the derivative of f with respect to t with x treated as constant.}$$
^ This.
And Leibniz's rule is really just what you get by combining FTC and the chain rule.
