Infrared Drying for firecrackers. Possible?
  • Thread starter Thread starter kunalv
    Drying Infrared
Infrared drying for firecrackers is being considered as a more sophisticated alternative to traditional sun drying. The proposal involves using a tunnel with infrared panels to control temperature and conveyor speed for effective drying. Concerns about dust explosions and static discharge risks are significant, necessitating careful design and grounding of materials. Questions remain regarding optimal drying temperatures, duration, and throughput capacity compared to sun drying methods. Overall, while infrared drying presents potential benefits, safety measures must be prioritized to prevent ignition hazards.
kunalv
Hello.
We've been entrusted the job of building a dryer for firecrackers. We were approached by a huge firecracker manufacturing firm here for the job. The current MO of drying is simply laying the product out in the sun and allow evaporation of moisture.
But now they plan to go in for a more 'sophisticated' approach.
I know that the whole concept of heating the firecrackers to dry them sounds crazy. But, I believe if I pass them through a tunnel with infrared panels used for drying, and by controlling the temperature and speed of the conveyor, I might be able to achieve it.
Then again, I'm aware of the concept of dust explosion.
If anyone can provide some good insight into the topic, it'd be greatly appreciated.
Thanks !
Would freeze drying work?
Sounds like an interesting idea...
Is there experimental data how long at which temperature firecrackers need to get dry?
How many firecrackers per time? That is a critical point, your tunnel won't be as large as areas with sunlight.
I like the "Related discussions" below, vacuum drying. Wonder if it even works like that?
Vacuum drying with a cold condenser would seem the way to go.
However, beware that very dry conditions increase risk of static electric discharge and ignition of the fireworks, which is one reason for using wooden implements and make sure metals are well grounded.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
