Exam in 2 days Change of basis BRA and KET
rwooduk
ive been revising all holidays, unfortunately I've just realized I've been finding eigenvalues using the ensemble when i may have to change basis for the exam. looks at homework questions, workshop questions... nothing!
anyway an example problem:
rewrite
|PSI> = a|0> + b|1>
in the basis
|phi1> = a|0> + b|1>
|phi2> = b*|0> + a*|1>
my attempt
im assuming that to change basis you need to use the identity operator with the new basis, in this case
I = |phi1><phi1| + |phi2><phi2|
so I|PSI> = |PSI>
which looks a bit strange to me.
ANOTHER example
write:
|PSI> = 1/SQRT2 (|0> + |1>)
in the basis:
|3> = SQRT(1/3) |0> + SQRT(2/3) |1>
|4> = SQRT(2/3) |0> + SQRT(1/3) |1>
my attempt
I = |3><3| + |4><4|
I|PSI> = |PSI>
Please could someone confirm my method is correct before i make an *** of it in the exam. any help once again appreciated!
I have no idea what you think you're doing in your attempted solution. And I have no idea what you meant by "using the ensemble". But maybe the following will help.
rwooduk said:
|PSI> = a|0> + b|1>
in the basis
|phi1> = a|0> + b|1>
Treat the last 2 equation as a pair of simultaneous equations in the unknowns |0> and |1>. I.e., express |0> in terms of |phi1> and |phi2>. Similarly for |1>. Then... (I'll leave the final step to you).
I'm not sure that way would work correctly. I am using the identity operator to change basis, which I think is the correct way. (could be wrong lol)
but thanks anyway
Well, I suggested a "low-brow" method of solution, since you seemed to having trouble with the "higher-brow" way of using a resolution of identity. So maybe you should solve the problems both ways to check that they eventually give the same answer.
HOWEVER, are you sure the new bases in both examples are as per the original question (or did you just make them up). Hint: check whether the new basis states are orthonormal. Are you sure you don't have a wrong sign somewhere?
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
