How to Calculate Work to produce a Vacuum?
  • Thread starter Thread starter Arnak
    Vacuum Work
To calculate the power requirements for an electric motor evacuating a vacuum, one must consider the torque needed based on the differential pressure created by the pneumatic cylinder. For a 50 mm bore cylinder achieving 2.5 psi, a force of approximately 37.7 pounds is required. The motor's power will also depend on the rate of air removal, which must exceed the leakage rate to maintain the desired vacuum. Additionally, the connection method to the motor, such as using a crank, will influence torque calculations. Understanding these factors is essential for accurately determining motor specifications for vacuum applications.
Arnak
Hi Folks,
Could someone please help me?:blushing:
I want to work out the power requirements for the torque or wattage required in an electric motor when evacuating a vacuum to a certain level.
The tube to be evacuated is 200 mm x 50 mm and the evacuation would be done using a pneumatic cylinder of 50 mm bore and 50 mm stroke.
The vacuum to be achieved and maintained is 2.5 psi or 5" Hg.
The pneumatic cylinder will be driven by an electric motor but how to calculate the motor requirements?
To keep it simple I will ignore losses due to friction etc.
Could someone could please help me with the formula to work that out?:confused:
Thanks,
Arnak
It's the same as the work required to reduce pressure.
Opposite of the work required to generate the pressure.
Depends a great deal on how the pressure is being changed.
It will not be easy to model from first principles - you should probably just look it up.
See how other people solve the same problems.
http://www.gastmfg.com/vphb/vphb_s4.pdf
http://lpc1.clpccd.cc.ca.us/lpc/tswain/chapt3.pdf
Likes 1 person
I believe the cylinder rod area is unimportant if the rod end of the cylinder is open to atmospheric pressure. The 50mm pump cylinder will have 2.5 psi on one face and 14.5 psi atmospheric on the other. That makes a differential pressure of 12 psi. The area of a 50mm piston is about Pi square inches so you need to apply a force of Pi *12 psi = 37.7 pounds force to the rod.
Torque cannot yet be calculated because you have not explained how you will couple the rod to the motor.
The ongoing cost of maintaining the 2.5 psi absolute pressure will be determined by the leakage rate you must make up.
The motor power requirements will be decided by the time you have available to pull the initial partial vacuum.
The rate of air removal must be faster than the leakage rate you need to make up.
Likes 1 person
Hi,
Thanks for all the advice, complicated subject isn't it.8-((
I will look up the links and see what I can learn.
The connection to the motor will be via a 2.5" throw crank to the motor shaft.
Good point about the leakage rate.8-))
Arnak
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
