Improving Performance of HP.115 Simulator Model: Challenges and Solutions
  • Thread starter Thread starter Babb
    Model Simulator
The discussion centers on the challenges faced in improving the performance of the Handley Page HP.115 simulator model, specifically regarding speed and vertical climb capabilities. The user has already converted 3D data to 2D airfoil data and corrected induced drag, yet performance remains suboptimal, with maximum speeds around 180 knots and vertical speeds of only 800 ft/min. There is a focus on achieving more accurate drag coefficients (Cd) to enhance performance, as the current drag appears excessively high. The user seeks advice on potential adjustments or assumptions that could resolve these issues. Overall, the conversation highlights the complexities of simulating aerodynamic performance accurately.
Babb
Hi everyone,
In my project work, I have to "rebuild" the Handley Page HP.115 aircraft, using the simulator in my university. It is a Merlin MP521 and I am using the Excalibur II model editor. The aircraft was used to test the slender delta wing planform at low speeds as part of the Concorde development program. So my model flies, but the overall performance is very bad. I can barely reach the maximum speed of about 180 knots, the vertical speed is maximum 800ft/min without loosing speed and it is not possible to recap the flight profile of the original: High angles of attack at low speeds. I got my Cl, Cd, Cm over alpha data from a student who made a CFD analysis of the wing. I already converted the 3D data to 2D airfoil data and corrected the induced drag but the performance is still bad.
Are there a possiblity to approach the correct Cd values? I guess the drag is still far to high.
Or any other assumptions which could fix these problems.
Thanks and Cheers
Babb
I'm sorry you are not generating any responses at the moment. Is there any additional information you can share with us? Any new findings?
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
