Are residues useful for proper integrals?
  • Thread starter Thread starter jinawee
    Integrals
jinawee
Calculating residues are useful when we are trying to solve some improper integral, because the Cauchy principal value will be the sum of residues inside the path taken (if the integral along the complex path tends towards 0).
When we have a proper integral of trigonometric functions, this is useful too.
But in general, are residues useful calculating proper integral?
It would be nice if I could apply the power of residues to evaluate an integral involving rational functions.
Although residues were developed primarily for evaluating complex integrals, they can be used to evaluate the integrals of real functions as well. Any decent text on complex integration should include a section on this topic.
This paper has some examples:
http://people.math.gatech.edu/~cain/winter99/supplement.pdf
I'm aware of that use, but I'm asking for definite integrals.
In general,
\int^{R}_{-R}f(x)dx+\int_{C_R} f(z)dz=2\pi i\sum \mathrm{Res}
For example,
\int^{10}_{-10}\frac{x^2}{x^6+1}dx=\frac{\pi}{3}-\int_{C_R} \frac{z^2}{z^6+1}dz
Where CR is a circular contour from 10 to -10. The problem is that the contour integral is not zero, so we would have something like this:
\int^{10}_{-10}\frac{x^2}{x^6+1}dx=\frac{\pi}{3}-\int_{C_R} \frac{x^2}{x^6+1}dz=\frac{\pi}{3}-i \int^{\pi}_{0} \frac{10^3 e^{i3\theta}}{10^6 e^{i6\theta}+1} d \theta
This method seems to complicate things. But is there any case where it's useful?
It's not clear why you want to use residues for this particular problem. It can be handled relatively simply by using substitution.
Sorry, I didn't explain myself correctly. It was just an example.
I just want to know if it could be useful for other definite integral that doesn't involve trigonometric functions (eliptic, hyperbolic...).
wikipedia http://en.wikipedia.org/wiki/Methods_of_contour_integration gives
$$\int_0^3 \frac{x^{\frac{3}{4}} (3-x)^{\frac{1}{4}}}{5-x}\,dx = \frac{\pi}{2\sqrt{2}} \left(17 - 40^{\frac{3}{4}} \right)$$
Periodic and improper examples are more common because closing the contour trades one integral for another. In order for the trade to be an improvement we need an integral to be easily found, zero, or expressible in terms of another. This happens often for periodic and improper examples, less so in other cases. Notice the above example takes advantage of another opportunity, branch cuts.
Likes 1 person
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
