Can you confirm the value of the g-factor for the spinning electron in H1?
The discussion revolves around calculating the g-factor for the spinning electron in hydrogen (H1) using classical physics. The mechanical orbital angular momentum and magnetic moment are defined, leading to the conclusion that the gyromagnetic factor γ is derived from the charge-to-mass ratio. It is noted that the classical expectation of a g-factor of 1 does not match the experimentally observed value of approximately 2.0023, highlighting a discrepancy that necessitates the g-factor's definition. The classical radius of the electron is mentioned but clarified as not relevant in the calculations. The conversation emphasizes the need to reconcile classical and quantum mechanical interpretations of angular momentum and magnetic moments.
bobie
I am studying the angular moment(s) in an atom of H (1s) in the classical model, can you help me understand some obscure points :
The mechanical orbital angular moment of the electron in 1s is L = mvr J*s:
(m) 9.11*10-31 *(v) 2.1877*106* (r) .52918*10-10 = 1.0546*10-34 J*s = h/2π,
the magnetic moment is μ = qvr/2 J/T:
1.6*10-19*(v) 2.1877*106* (r) .52918*10-10 /2=9.274 *10-24 J/T
first problem : this is the exact value of Bohr magneton μB (= qh/22πm), not of μ
The gyromagnetic factor γ (http://en.wikipedia.org/wiki/Magnetogyric_ratio) is the ratio μ / L : γ = qvr/2 *mvr = q/m2 (J/T / J*s =1/s*T) = 1.7588*1011/2 radian/s*T, γ = 8.79*1010 r/Ts
For the spinning electron wiki says:
As mentioned above, in classical physics one would expect the g-factor to be ge=1 ...(whereas it is 2.0023..., γe = 1.76*1011: q/m 1.7588*ge/2= 1.01169)
second question: how do I verify g=1, shall I take into account the electron classical radius 2.81*10-15 m* 9.11*10-31 kg and what speed?
Thanks for your help
What are you asking here? The definitions that you gave for L and μ are the classical definitions Using that definition the gyromagnetic ratio is just the charge to mass ratio (divided by 2). that relationship is not realized experimentally hence the need to define the g-factor that measures the discrepancy between the classical result and the observed value. The classical radius of the electron doesn't show up anywhere in either the classical or the quantum calculations.
Likes 1 person
In the article I quoted there is :
γ which is the ratio of the orbital momenta μ / L in H1 ( L = 1/2π and μ =q/2m).
γe which is the ratio ofbetween the electron "spin" angular momentum Le= \pm1/2 h/2π = h/ 4π, and magnetic moment μe/Le
and ge, the g-factor , the experimental factor that multiplies the expected classical, theoretical value of ye by 2.0023, if I got it right
The value of L in γ is mvr, where r should be the radius of the orbit in H1, Bohr radius
Isn't it so?
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
