Can somebody me with this problem
  • Thread starter Thread starter CougarPride
The problem involves calculating the torque needed for Tom, who weighs 150lb, to lift a 600lb stone lid using a 12ft lever positioned at a 30-degree angle. To lift the stone, the axis of the lever must be placed at a specific point that balances the torques exerted by Tom's weight and the weight of the stone. Understanding the principles of torque and lever mechanics is crucial to solving this problem. The discussion highlights the difficulty in grasping these concepts, emphasizing the need for clear explanations and guidance. Ultimately, finding the correct axis placement is essential for Tom to successfully lift the stone lid.
CougarPride
This problem involves torque, and levers. I am so stuck on this, I really have no idea where to even begin. The problem states:
"Tom weighs 150lb and he wants to lift a 600lb stone lid form a well. We give him a 12ft, unbreakable lever that has one end attached to the stone (at the COM), and a secure axis. He positions the lever at 30 degrees above horizontal to the ground, and places his hands 6 inches from the end of the lever. He hangs from the lever without "jumping around". Where would he need to place the axis to enable him to lift the stone lid?
I don't even know where to start with this problem. It is in our powerpoint on torques. I tried going to get help for this problem at tutoring, but was still unable to understand how to do the problem.
why the double post?
