What is the Torque at the rear wheel in this gear setup ?
  • Thread starter Thread starter ramonegumpert
    Gear Torque Wheel
The discussion focuses on the effective gearing and torque at the rear wheel of a bicycle powered by an electric motor. The setup includes a small gear connected to a large gear with a 5:1 ratio, which increases torque at the bottom bracket. The motor's pinion gear drives the large gear, and a second small gear connected to the large gear further reduces speed while increasing torque at the rear wheel. The overall gear ratio is confirmed to be 25:1, indicating significant torque multiplication at the rear wheel. The participants express satisfaction with the calculations and assumptions made regarding the gearing effect.
ramonegumpert
Dear Experts
A bicycle has the following gear setup. I like to get your advice what is the effective gearing and torque at the rear wheel that is being turned by a electric motor that is turning the whole gear set using a chain.
There are 2 gear sizes : small gear and large gear. Their gear ratio is about 5:1.
A electric motor is mounted onto the bicycle. It has a pinion gear of the small gear size.
This gear is connected to a large gear mounted on the bottom bracket shaft.
There is another small gear connected to the other end of this shaft. This is same size as the motor's pinion gear. This gear is connected to another big gear mounted on the rear wheel shaft via another chain.
I am not sure what is the gearing effect at the rear wheel.
I suspect, its like this :
1. when the motor turns, its pinion gear turns the bottom bracket large gear at a stepped-down ratio of 5:1 increasing the torque by 5 times.
2. The small gear at the opposite end of this large gear rotates at this stepped-down speed with this same torque even though the gear is smaller.
3. The Rear wheel rotates at a even slower rate because of the gearing ratio of a further 5:1 increasing the rear wheel torque to be more than the torque at the large gear mounted on the shaft in the bottom bracket.
Thanks for reading my question and hope to hear your advice.
Have a nice day.
regards
Ramone
ramonegumpert said:
Dear Experts
Have a nice day.
regards
Ramone
The gear ratio is: 25:1
Work it out this way: if the small gear has T teeth, the big gear has 5T teeth. So when the small gear turns twenty five complete revolutions (i.e. 25T teeth), the first big gear turns 5 revolutions (i.e. 25T teeth = 5 (5T) teeth). This means that the small gear to which the first gear is fixed also turns 5 complete revolutions (5T teeth). When the small gear turns 5 revolutions (5T teeth) the second large gear turns 5T teeth = 1 revolution.
AM
Likes 1 person
Thanks AM
for confirming that my assumption is correct.
yeah!
I wish you have a nice day.
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
