How is dark matter distributed in the Milky Way and what effects does it have?
Dark matter in the Milky Way is primarily concentrated in a halo that extends significantly beyond the galaxy's visible components, with a density profile that decreases with distance. The total mass of dark matter within a radius of about 300 kpc is estimated to be around 2 trillion solar masses, dominating the galaxy's mass. However, at smaller radii, such as the Sun's orbit (approximately 8 kpc), the dark matter density is relatively low at about 0.01 solar masses per cubic parsec. This low density means that the effects of dark matter are only noticeable at larger distances, as its influence is negligible within the solar system. Resources for further reading on dark matter distributions and properties are available, including articles and textbooks focused on modern cosmology.
Lapidus
How is dark matter distributed (as far as we know)?
Let's stay with a single galaxy like the Milky Way. I heard that dark matter is even more concentrated in the center than in the halo, that it is falling off when moving outside, but since the halo is so huge (how huge, ten times larger?) most dark matter can be found there. Is that correct?
So there is dark matter also in our solar system. But by what density? If the density would be high, we would have noticed it by the motion of the planets or nearby stars. Can the effect of dark matter only be seen at larger distances where it accumulates despite its low density?
thanks!
Space news on Phys.org
What you said is largely correct. There's lots of work to understand the Milky Way dark matter halo. One model (see this paper) is a density profile like:
\rho_{DM} = \rho_0 (r/r_s)^{-\gamma} (1+r/r_s)^{-3+\gamma}
with gamma = 1.24, rs = 28.1 kpc, and rho0 = 3.5E-3 Msun/pc^3.
This profile never goes to zero, so it is hard to characterize how "big" it is, but one way that is often used is to ask at what radius does the density drop off to 200 times the average density of the universe. For this profile, this is atound 300 kpc, so about 10 times the size of the Milky Way galaxy. Within this radius, this profile has a total mass of about 2E12 Msun, so it dominates the mass of the galaxy. However, at smaller radii, the ordinary matter dominates. If we look at the radius of the sun (r = ~8 kpc), then the dark matter density is about .01 Msun/pc^3. We can then ask how much dark matter is, say, inside Saturn's orbit, and the result is about 1E-18 Msun or about 7E15 kg. This is the mass of a small asteroid, and is completely negligible compared to the mass of the sun and planets. Does this answer your questions?
Likes exmarine and Lapidus
Yes, that answers my question, thanks!
Btw, does anybody know a great review/ overview article (or a book or sections of a book) about dark matter? One that is not complete layman but not complete specialist either.
thanks!
thanks!
my signature contains numerous article that have sections covering dark matter. Most articles directly related to DM are related to distributions, properties etc of specific proposals and models. the misconceptions section on the http://cosmology101.wikidot.com/main signature link has one decent non technical article with a dark matter section. The articles on the site are primarily geared to helping teach modern cosmology. In particular the FLRW metrics etc. There are some textbook style articles on cosmology that include DM modelling.
http://arxiv.org/abs/1304.4446 :"What we have leaned from Observational Cosmology." -A handy write up on observational cosmology in accordance with the LambdaCDM model
you can also browse www.arxiv.com however keep in mind what I stated above, concerning the numerous alternate proposals.
Likes 1 person
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
Why was the Hubble constant assumed to be decreasing and slowing down (decelerating) the expansion rate of the Universe, while at the same time Dark Energy is presumably accelerating the expansion? And to thicken the plot. recent news from NASA indicates that the Hubble constant is now increasing. Can you clarify this enigma? Also., if the Hubble constant eventually decreases, why is there a lower limit to its value?
