Is all the charge inside a conductor evenly distributed in equilibrium?
  • Thread starter Thread starter Hardik Batra
    Charge Conductor
In a solid conductor at static equilibrium, there is no net charge inside, meaning positive and negative charges balance out, but free electrons still exist within the material. When a potential difference is applied, current flows due to the drift of these free electrons, not solely from charges on the outer surface. The surface charge creates an electric field that facilitates this current flow throughout the conductor's volume. Therefore, while there is no net charge inside, the presence of free electrons allows for current to circulate within the conductor. This understanding clarifies that current is not limited to the surface but involves the entire volume of the conductor.
Hardik Batra
As we know there is no charge inside the conductor.(Consider the solid conductor...)
All the charge will distributed on the outer surface of the conductor.
There is no charge inside the conductor
My question is when we applied potential difference across this conductor then current will flow through this conductor. Here current constitute by the charge that will reside on the outer most surface ?
since there is no charge inside the conductor because all the charge will reside on the outer most surface of the conductor.
So that no current is flowing inside the conductor.
This is the property of the conductor.
If I am wrong explain it.
No, we don't know this. Do yo think that all the electrons and protons of the atoms of the metal migrate to the surface? :)
What we actually know is that there is no NET charge inside a conductor in STATIC equilibrium.
This means the number of positive and negative charges is equal in any "small" volume. So there are many free electrons inside the metal. And an equal number of positive charges that are not so free.
When we have a current some of the free charges (electrons) have a net drift through the metal.
For low frequency current the motion happens pretty much in the whole volume.
There is some net surface charge on the surface too. This produces the electric field that drives the current.
Likes 1 person
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
