How can I calculate the F-terms for chiral superfields in a no-scale model?
  • Thread starter Thread starter ChrisVer
    Model Term
ChrisVer
In case you have the Kahler and super- potential K,W:
K(T,S,C) = -log (S +S^{*}) -3 log ( T+ T^{*} - C C^{*})
W(T,S,C)= C^{3} + d e^{-aS} +b
with T,S,C chiral super fields, b,d complex numbers and a>0.
I tried to calculate the local F-terms arising from this. The local F-terms for the i-th chiral superfield are given by:
F_{i}= D_{i}W = K_{i}W + W_{i}
where in the rhs the index i denotes the derivative wrt to the i-th field. eg W_{S}=\frac{\partial W}{\partial S}
However I'm having a slight problem with the particular derivative. See what I mean...taking it:
F_{S}= K_{S} W + W_{S} = - \frac{C^{3} + d e^{-aS} +b}{S+S^{*}} -d a e^{-aS}
correct?
On the other hand, if I try to work with the covariant derivative wrt to the conjugate fields:
F^{*}_{S}= D_{S^{*}} W^{*} = K_{S^{*}} W^{*} + W_{S^{*}}
I don't get the complex conjugate of the above. Because in this case
W_{S^{*}}=0
and so:
F^{*}_{S}= - \frac{(C^{3} + d e^{-aS} +b)^{*}}{S+S^{*}}
what's the problem?
Ah found the mistake... again by writing in LaTeX it became obvious- In the F* equation I needed the W* derivative as the second term...
However
In the case of F let's say... How can I see if its module squared is simultaneously zero or not?
|F_{T}|^{2}= \frac{9}{(T+T^{*} - CC^{*})^{2}} |C^{3}+ d e^{-aS} +b |^{2}
|F_{S}|^{2}= | \frac{C^{3} + d e^{-aS} +b}{S+S^{*}} + d a e^{-aS}|^{2}
|F_{C}|^{2}= | \frac{3 C^{*} (C^{3}+d e^{-aS} +b)}{T+T^{*}-CC^{*}} +3 C^{2}|^{2}
