Potential Energy of a Charge Configuration
Calculating the total potential energy of a charge configuration involving multiple charges typically requires summing the potential contributions from each charge. In the example of a 2D square with charges at each corner, there is no shortcut to avoid this summation process. The consensus is that a detailed calculation is necessary, as quick methods do not exist for such configurations. The discussion highlights a frustration with tedious calculations in exams, contrasting with the professor's usual approach. Ultimately, understanding the underlying concepts remains essential despite the workload involved.
CogitoEAS
Is there a quick way to figure out the total potential energy between more than 2 charges without having to find the potential at each point and the. Multiplying it by the charge at that point and adding it all up?
For example - a 2D square with a charges Q, 2Q, -3Q, and another Q at each corner and let's say each side of the square has length "d"
I'm basically wondering if there's a way to calculate the total potential energy of this charge configuration without a page and a half of work
There really isn't a "quick" way that I know of. You pretty much have to do a sum when calculating the potential energy. That's just the way it's done.
Thank you -I figured as much. I just have a professor who typically writes problems that aren't very tedious especially when you understand the concept(s). I saw a problem like this on an old exam and thought the busywork I had to do was a little uncharacteristic of his testing style.
Thanks again.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
