What values of z in the complex plane make the series absolutely convergent?
The discussion focuses on determining the values of z in the complex plane for which the series ∑(1/n!)(1/z)^n is absolutely convergent. Participants suggest using the ratio test to analyze the convergence of the series. One user points out that the series resembles the exponential function exp{1/z}, which aids in understanding its behavior. The original poster expresses a desire to improve their understanding and acknowledges their struggles with the concepts. Overall, the conversation emphasizes the importance of logical reasoning and clarifying complex series convergence.
heman
Hi,
In this Problem i am finding Problem to calculate the set of z:
Pls help
Determine all z \subset C for which the following series is absolutely convergent:
\sum (1/n!)(1/z)^n
Thx
Mathematics news on Phys.org
Do the terms look familiar? What if you set w=\frac{1}{z}?
okay ...but generally how to solve such kind of problems..can u be more logical pls
Use the ratio test (and i don't think you should accuse others of not being logical. pointing out that this is the series for exp{1/z} give or take a constant is very logical. you ought to put in the limits too).
its just my concepts are not clear...how can i accuse anyone here..i have learned a lot from ppl here and i want to improve
Sometimes even in my class i end up asking such stupid questions that whole class bursts into laughter..
Thx for it and urs reply in pm...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
