Need help understanding a concept in Gyroscopes
Mounting two gyroscopes with their axes at right angles creates a stable platform that maintains its orientation in space due to the principles of conservation of energy and momentum. This stability is contingent upon precise balancing, minimal friction in bearings, and operation in a vacuum. The gyroscopes provide reference axes relative to the stars, allowing for accurate orientation detection. Any change in orientation requires an external force, as the system inherently resists changes without it. Understanding these concepts is crucial for applications like gyrotheodolites and vehicle stabilization systems.
ME101
So I've been trying to understand a concept in gyroscopes and I hope the guys and girls here can help me with it.
I first read it here, the part about mounting 2 gyroscopes with their axes at right angles to each other. It said that the platform will remain totally rigid.
I tried to consult a few of my teachers about this but none of them seemed to have an answer why. I've been searching online and the closest I came to finding something that relates is an old US patent No. US3398586. Fig 1 seems to be working around the same concept.
So does anyone here know why this happens? Any help would be greatly appreciated. Thank you and have a great day.
No forces may be transformed by the gyroscopes, without causing precession. The platform with the two gyroscopes must therefore be free to rotate space, or mounted in gimbals on a vehicle.
One gyroscope can give you a single reference axis direction, relative to the stars. It takes a second gyroscope, with an axis that is not parallel with the first, to resolve another direction. Given those two axial directions you know platform orientation relative to the stars.
A vehicle can be made to remain stable by sensing vehicle orientation relative to the gyro platform and applying torque to the vehicle to correct the vehicle orientation.
Hi Baluncore and thank you for your response. I just want to know that if two gyroscopes with perpendicular axes are mounted on a platform that is in turn mounted on gimbals, will the platform maintain its orientation in space such that the gimbals rotate? If it does, why does that happen?
Yes, it will be stable, but only if it is precisely balanced, has no friction in the bearings and is operated in a vacuum.
It must obey principles of conservation of energy and momentum. Without some external force being applied there can be no change in orientation. http://en.wikipedia.org/wiki/Gyroscope#Properties
It turns out that a gyroscope's frame of reference is the same as the stars. It is called a “gyroscope” because it was originally intended to demonstrate that the Earth rotates. http://en.wikipedia.org/wiki/Gyroscope#History
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
