Log Questions: Answers to x=2 & x=10^3
  • Thread starter Thread starter Death
The discussion addresses two logarithmic problems that require clarification on their solutions. In Problem 1, the equation simplifies to log3(1/(x+1)) = -1, leading to x = 2 after solving. Problem 2 involves the equation 6logx = 2(logx)^2, which simplifies to 3 = logx after dividing both sides by 2logx. This results in x = 10^3. The participants confirm the steps taken to arrive at these solutions, ensuring clarity in the logarithmic transformations.
Death
I need some help on two log questions. I do understand everything of the problem until the final answer, it does not make sense.
Problem 1:
log3(x-1)^2 - log3(x^2 -1) = -1 + log3(x-1)
2log3(x-1) - log3(x^2 -1) = -1 + log3(x-1)
2log3(x-1) - log3(x-1) - log3(x^2 -1) = -1
log3 x-1/(x-1)(x+1) = -1
log3 1/x+1 = -1
=3^-1 = 1/3
x = 2 <=== why does it equal two?
Problem 2:
logx^5 + log x = (log x)(2logx)
5logx + logx = 2(logx)^2
6logx = 2(logx)^2
3 = logx <=== why does it equal 3? How does it turn from 6logx to 3?
x = 10^3
Thank you!
Mathematics news on Phys.org
Problem 1:
log3 1/x+1 = -1
=3^-1 = 1/3
Problem 2:
6logx = 2(logx)^2
x = 10^3
Thank you!
Problem 1
You got a little sloppy with parentheses
log3 1/x+1 = -1
should be
log3 (x-1)/(x-1)(x+1) = -1
log3 1/(x+1) = -1
raise three to the power of each side yields
1/(x+1)=3^(-1)=1/3
1/(x+1)=1/3
x+1=3
x=2
Problem 2
6logx = 2(logx)^2
both sides were divided by 2logx
6logx/2logx=3
2(logx)^2/2logx=logx
Njorl
Thanks buddy.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
