Can a rigid object transmit a signal faster than the speed of light?
A rigid object cannot transmit a signal faster than the speed of light; instead, the signal travels at the speed of sound within the material. When a rigid rod is pushed, it compresses and this compression propagates through the rod at a speed determined by the material's properties, which is always slower than light. The concept of a perfectly rigid object is theoretical, as all materials exhibit some degree of compressibility. Even in extreme cases, like neutron stars, the speed of pressure waves approaches but does not exceed the speed of light. Ultimately, the discussion highlights the complexities of applying physical laws to idealized scenarios and their implications for understanding reality.
madness
If I push a rigid object at one end, the whole rod should move instantaneously. Would this mean that a signal has been transmitted from the end which is pushed to the the far end faster than the speed of light?
Science news on Phys.org
Nope, much slower. It's transmitted at the speed of sound for that material, which makes sense, seeing as sound travels merely by movement (well, vibration) of particles.
There is no such thing as a perfectly rigid object. The rod will compress when you push it and that compression will travel the length of the rod at the speed of sound for the rod's material (at less than the speed of light), until it reaches the end and uncompresses. Net effect, you push your end, and at sometime later the other end of the rod moves. the time delay between the movement of the ends of the rod will always be longer than it would take for light to traverse the length of the rod.
I seem to remember something about splitting up pairs of electrons into opposing paths, and how one of them observed at one end affects the other?
This thread is not about entanglement, and even though the thread topic is broad enough to accommodate that, let's stick to the content in the OP.
I've seen this "thought experiment" come up on several forums, and it usually generates a lot of argument. I think the problem is that this question doesn't really have an answer, because once you start applying physical laws as restrictions to help you narrow down the possibilities, you have to change the nature of the question. I think it's really designed to get you thinking about what the laws really require of reality, and what the consequences are of the gaps between quantum mechanics and relativity. Not to get an interesting definite answer.
The short answer is that it will take the amount of time required for the eletromagnetic force to transfer your pressure at one end from one atom to the next all the way down the rod. In other words, as someone already stated, the speed of sound is the factor. However, this assumes a certain amount of compressibility at the atomic level. Which means the rod isn't truly rigid. If the rod were perfectly rigid, then the answer to your question would be "yes". However, it would also have no physical significance, as the scenario varies so widely from anything possible in reality. Except maybe a neutron star, which some people think may be regarded as being as close as possible to being incompressible without collapsing to a black hole. It is thought that the speed of pressure waves (and hence sound) through neutron star material is very close to the speed of light.
"Rigid" materials are good for messing around with ideal scenarios of laws which don't deal specifically with phenomena that are pushed to their limits by "rigid" materials.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
