Where can I find a 100V DC power supply with 15A output?
  • Thread starter Thread starter eschafer
    Transformer
A user is seeking a transformer to convert 115VAC to approximately 100VDC with a 15A output. It is noted that while 115V to 100V is uncommon, contractor's power tools often utilize isolating transformers that can handle around 1kW. A variac is suggested for adjusting the AC voltage to about 70VAC before creating a rectifier circuit for DC conversion. However, it is advised that only those with experience in high voltage circuits attempt to build their own rectifier. Commercial options for a 100VDC power supply, such as the Agilent N5769A and products from Kepco, are recommended for those who prefer not to DIY.
eschafer
Hi all,
I am looking for a transformer to convert the 115VAC from the wall to ~100VAC, 10-15A, and 1-1.5kW. Is something like this commercially available? Otherwise how difficult would it be to make?
Thanks a lot.
115V to 100V is unusual, generally equipement isn't that specific - its built to take a small range of inputs just to handle unreliable supplies.
Generally contractor's power tools have to run through a 115V isolating transformer - these shoudl be able to handle 1Kw and are pretty cheap and easy to get.
mgb_phys,
Thanks very much for the help.
I actually had a typo in my original post however. Our goal is to tranform the 115VAC from the wall to 100VDC. So for the AC transformer I believe I would be looking to convert 115VAC to ~70VAC (=0.707*100Vp).
Try getting a variac (variable transformer) which may be adjusted to get 70 Vac. Then you're on your own to make a rectifier circuit for the DC.
By the way, I would not do this (making your own rectifier circuit) if I didn't already have experience making circuits that work at these high voltage and current levels that you are talking about.
EDIT:
Ah, what am I thinking? Just get a 100 Vdc power supply, at the current and power level you need.
Your calculations only apply if the transformer is lightloaded and you have a sufficiently large smoothing C. How much ripple can you tolerate?
Output voltage depends on the power rating of the transformer and how much it is loaded. It is not clear cut.
Maybe there are high current 115 to 115 isolation transfomers available. ...used on building sites. Nearest you will get.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
