Why Do We Consider All Ka Values in H3PO4 Neutralization with NaOH?
  • Thread starter Thread starter lkh1986
In the neutralization of phosphoric acid (H3PO4) with sodium hydroxide (NaOH), the three dissociation constants (Ka1, Ka2, Ka3) are considered, but Ka3 is often neglected due to its small value. The stepwise reactions show how H3PO4 reacts with NaOH, producing various phosphate salts, but the advancement of each reaction diminishes, indicating that the reactions are not entirely quantitative. The third dissociation of H3PO4 contributes negligibly to the hydronium ion concentration when H3PO4 is the sole acid in solution. However, when calculating pH during the neutralization, it is essential to consider the stoichiometric ratios of the reactions. This approach differs from that of diprotic acids, where the contributions of all dissociations are typically more significant.
lkh1986
For the triprotic acid, phosphoric acid, H3PO4, there are Ka1, Ka2,
and Ka3. And we know from the book that the value of Ka3 is too
small, so we neglect the [H+] contribution from it.
Normally, we encounter questions involving pH calculations of
neutralization of a diprotic acid and a base, for example, H2SO4 and
NaOH. Let say there are 5 mmol of H2SO4 and 10 mmol of NaOH.
The stepwise reactions are:
H2SO4 + NaOH ---> NaHSO4 + H2O
---5-----------10------------0---------------
---0-----------5--------------5---------------
NaHSO4 + NaOH ---> Na2SO4 + H2O
----5-----------5-------------0---------------
----0-----------0--------------5--------------
However, if the reaction is between H3PO4 and NaOH, let say there are
5 mmol H3PO4 and 15 mmol NaOH.
H3PO4 + NaOH ---> NaH2PO4 + H2O
----5---------15------------0-----------------
----0---------10------------5-----------------
NaH2PO4 + NaOH ---> Na2HPO4 + H2O
----5------------10--------------0---------------
----0-------------5--------------5---------------
Na2HPO4 + NaOH ---> Na3PO4 + H2O
----5------------5--------------0--------------
----0------------0--------------5--------------
So, are the 3 equations above correct? I mean, can we use the 3
equations above for calculating the pH value, as what we would do for
the case of the neutralization involving a diprotic acid and NaOH?
If so, why do we neglect the [H+] from H3PO4?
Or is it that we ONLY neglect the [H+] from Ka3 when we calculate the
pH of a solution containing ONLY H3PO4, but we should
somehow "include" and "consider" the Ka3 when we wish to find the pH
value of a solution involving neutralization of H3PO4 and NaOH, since
this neutralization reaction is based on the stoichiometric ratio.
Thanks.
You are right.
You can prove that H3PO4 third dissocitation is negligible as long as H3PO4 is the only source of hydronium ions in solution. ( either generally or u can take a numerical example and try it out yourself . )
But notice that the reactions u posted :
are not entirely quantitative. that is , the advancement decreases from one reaction to the other. For each rxn , k = ka/kw . Notice the 3rd rxn is much weaker than the 1st reaction , which is pretty much 'complete'. You can find the ka's and calculate the K of each reaction to convince urself. Finding the pH here is different from that of sulfuric acid.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
