Calculating Space Shuttle Velocity: Astronaut Melroy's Historic Flight
  • Thread starter Thread starter beachbabe0191
Astronaut Pam Melroy undocked the space shuttle Discovery from the International Space Station in October 2000, using four large springs to push away. The problem involves calculating the shuttle's velocity after separation, given the space station's mass of 73,000 kg moving at 0.50 m/s. The initial calculations showed the shuttle moving at approximately 0.54 m/s, but it was clarified that the relative speed of separation includes both the shuttle's and the space station's velocities. Thus, the total separation speed is 1.04 m/s, combining the shuttle's speed with the space station's. This highlights the importance of considering both spacecraft's movements in velocity calculations.
beachbabe0191
Problem Statement: Astronaut Pam Melroy, history's 3rd woman space shuttle pilot, flew the space shuttle discovery to the International Space Station to complete construction in October of 2000. To undock from the space station, Pilot Melroy released goooks holding the 2 spacecraft together and the 68 000-kg shuttle pushed away from the space station with the aid of 4 large springs.
A) if the 73 000-kg space station moved back at a speed of 0.50 m/s, how fast and in what direction did the space shuttle move?
B) What was the relative speed of the 2 spacecraft as they separated?M_{1}= 68 000-kg
V_{1F}= ?
M_{2}= 73 000-kg
V_{2F}= -0.50 m/s
V_{o}= 0 m/s
(M_{1} + M_{2}) V_{o} = M_{1}V_{1F} + M_{2}V_{2F}
(68 000-kg + 73 000-kg)0 m/s = ((68 000-kg)( V_{1F} ) + (73 000-kg)(-0.50 m/s)
0 = (68 000-kg)V_{1F} - 36 500-kg \timesm/s
add -36 500-kg \timesm/s to 0
36 500-kg \timesm/s = (68 000-kg)V_{1F}
= 0.53676 m/s
BUT the back of the book for this odd says
1.04 m/s
needs help very very very fast
It is asking you the speed they separate, remember that the ISS is also moving so it is the total speed between them.
You have worked out the speed of the shuttle from the starting point.
so my answer is the initial velocity??
No the answer is 0.5m/s for the iss plus 0.53676 m/s for the shuttle
So the velocity they are moving apart is 0.5 + 0.53676 = 1.04m/s
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
