How Long Must Zorch Push to Extend Earth's Rotation to 29 Hours?
  • Thread starter Thread starter blimkie
    Physics Year
Zorch aims to slow Earth's rotation to 29 hours by applying a force of 4.65×10^7 N at the equator. The moment of inertia for Earth is given as 9.71×10^37 kg·m^2, and the radius is 6.37×10^6 m. Initial calculations for angular acceleration were incorrect due to neglecting the Earth's radius and the proper units. To find the time required for the change in angular velocity, the angular acceleration should be calculated in radians/second^2, and the equation ω=ω_0 + αt should be used. Properly using symbols in calculations can simplify the process and reduce errors.
blimkie
i need help with this problem
N.B. See eq. 13.26 and table 13.2 on p.382
11. [1pt] Zorch, an archenemy of Superman, decides to slow Earth's rotation to once per 29.0 h by exerting an opposing force at the equator and parallel to it. Although Superman knows that Zorch can only exert a force of 4.65×107 N (a little greater than a Saturn V rocket's thrust), he isn't sure if it is an immediate concern. Assuming that Earth's moment of inertia for such a process is 9.71×1037 kg·m2 and that its radius is 6.37×106 m, how long would Zorch have to push with this force to accomplish his nefarious goal?
Heres what i did so far..
here is the equation shown in the book a = T/I
a=angular acceleration
T=net torque
I=moment of inertia
so i determned the acceleration is 4.789x10^-31 m/s^2
then i used v=(2)(pi)(r)/T to find the veocity of Earth with the periods of rotation at 24 hours and 29 hours
v at 24h = 1.667x10^6 v at 29h = 1.379x10^6
so then i used the formula
Vf = Vf + a(t) i solved for t and my answer was 6.01 x10^35
when i entered my answer into the online homework grading system it was wrong and i have checked my work and ended up with the same answer twice so i guess I am just using the wrong approach
if anyone could help me that's great thanks
When you calculated the angular acceleration, you forgot to consider the radius of the earth. And this is angular acceleration, so its units are radians/second^2. After you've found this, you can calculate the time it takes for the Earth to reach its new angular velocity by using the angular equivalent of the equation you selected: \omega=\omega_0 + \alpha t.
P.S. One way to make this problem (and others in the future) easier is to use symbols until you reach the final equation, into which you can plug in all the given information. That way, you won't be fumbling with big crazy numbers all over the place, and it will be easier to see mistakes.
